1993 power window short on driver side fix? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2006, 08:04 PM   #1 (permalink)
View steve273's Photo Gallery
My window controls on the drivers side are not working. When I wiggle the rubber sheath, the power window lights up and the window controls work temporaily. Is there any way to fix this problem permanently? Any help would be appreciated.
steve273 is offline   Reply With Quote
Old 09-27-2006, 08:51 PM   #2 (permalink)
View toyomoho's Photo Gallery
Not sure what the rubber sheath is?
Old 09-27-2006, 09:00 PM   #3 (permalink)
The Greek....
GrkBallaG's Avatar
iTrader Score: 13 reviews
View GrkBallaG's Photo Gallery
If by rubber sheath you mean drivers door boot where all the wires go through to go to the kick panel than the only way to fix that is to disconnect the connector that goes inside the kick panel, pull it out through the hole and out the door, than repair the wires, and put it back.
Trust me, i know... A similar thing happened to me about 2 months ago. My drivers door lock would not operate but all the others would..... than all the doors would only lock and not unlock. Anyway long story short, i pulled back the rubber from the boot and found 6 broken wires, fixed them and everything is back to normal.
The SLAMry.....
Slammed, Carboned, 5sp Swapped, Big Braked, RMM Lipped And Ready To Be Daily Driven!
Originally Posted by UfoZ View Post
Tits! Best non turbo Camry there is.
GrkBallaG is offline   Reply With Quote
Old 09-28-2006, 04:46 PM   #4 (permalink)
That is exactly what I mean by sheath. What so you mean by disconnecting the connector inside the kick panel. Do I have to remove the door liner and how hard is this process. Or can I simply pull back the rubber?
Old 09-28-2006, 07:48 PM   #5 (permalink)
The wires are most likely damaged where they go from the door to the car body. You will need to remove the wires from the drivers control module (pull them off the connector terminal). Then pull them out of the door, rubber sleeve and car body. Once done, they need to be repaired and reinstalled. You will need to remove the door panel to get at the control module.
Old 09-29-2006, 12:10 AM   #6 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
I have the SAAAAMMMMMMMMMMMMMEEEEEEEEEEEEEEEEE problem but on the door behind the driver. If I wiggle the rubber boot between the door and the pillar while holding the window switch up, it will finally go up. I also cant lower or raise the window from the master switch.
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 07-13-2007, 07:31 PM   #7 (permalink)
WALKING AND TRAVELING SUX
View umeshr85's Photo Gallery
HELP. i messed with the kill switch or bypass switch on my alarm, i replaced it. anyway. my alarm stopped beeping and it doesnt make noise anymore at all, but still closes and uncloses the doors. the controls on the driver's door no longer work, the door lock and unlock button works, but the 4 window buttons dont work. the windows do however go up and down when using the windows controls on each door. thanks. whats wrong with my car? think its a relay? or just replace the whole master controls? THANKS.
PARTS FOR SALE: http://www.toyotanation.com/forum/sh...d.php?t=302022
I install headunits,amps, subs,speakers in NYC. Private message me.
umeshr85 is offline   Reply With Quote
Old 07-13-2007, 08:53 PM   #8 (permalink)
here is how to troubleshoot it. i checked the wires in the black plastic loom between the door and the fender part of the car by the a pillar. there are wires that are joined and black taped but they seem fine. and i could not see a flasher behind the ashtray, maybe there is one, but i'd have to take off the plastic around the center console, so i disconnected the master window controls from the drivers side door and what do you know, the alarm was working fine again. so the controls are defective, the unit. i'll pick one up somewhere. do you think that i caused it to stop working yesterday when i changed the alarm bypass switch by the kickpanel? i also pushed the controls down a little, by hand with force, cuz it was sticking up a bit. thanks.
Avalon and Impala score best among IIHS side crash test results for large sedans IFCAR Toyota News 1 06-24-2006 05:28 AM
Need Help Finding Rear Driver Side Window Ghetto2315 Archived Corolla threads 1 06-23-2006 06:46 PM
1990 Front Driver Side Power Window ncampb4861 1st & 2nd Generation (1983–1986 & 1987-1991) 0 11-08-2004 12:33 PM
Master power window control...short?? tca1 General Discussion 1 10-23-2004 08:47 AM
could you get away with it bondobondo General Discussion 46 07-06-2002 12:00 PM
