Tranny fluid question. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2006, 08:19 PM   #1 (permalink)
Toyota..Moving Forward-->
djarno's Avatar
View djarno's Photo Gallery
3rd Generation Tranny fluid question.
Is it okay to use Mobil 1 Synthetic ATF in my '95 Toyota Camry(Auto transmission). I plan to change the fluid in my car but I am unsure if the synthetic fluid will be compatible.
I heard that you do not need to buy a new transmission filter. You can just wash it off with new tranny fluid. Is this true?
Also, will I need a new gasket when changing my transmission fluid?
'95 V6 Camry LE
'04 V8 Tundra
http://www.cardomain.com/ride/2305303
djarno is offline   Reply With Quote
Old 10-03-2006, 08:23 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
If the suggested fluid for your car is Dexron III, you can use Mobil Synthetic ATF. It states on the back that it is compatible with DexIII.
The transmission screen just needs to be rinsed with clean fluid.
2007 Camry 2.4L 5M
Old 10-03-2006, 08:37 PM   #3 (permalink)
djarno's Avatar
My manual states that it takes DEXRON II. Is it still okay to use synthetic fluid or do I have to stick with the conventional type? Thanks.
'95 V6 Camry LE
'04 V8 Tundra
Old 10-03-2006, 08:51 PM   #4 (permalink)
I believe that Dexron III replaces Dexron II
2007 Camry 2.4L 5M
Old 10-03-2006, 08:53 PM   #5 (permalink)
djarno's Avatar
Okay, I shall use Mobil 1 Synthetic ATF as my new fluid. Thanks!
'95 V6 Camry LE
'04 V8 Tundra
Old 10-04-2006, 12:10 PM   #6 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
Correct. Dexron III has superseded Dexron II and is fully backwards compatible.
DFBonnett is offline   Reply With Quote
Old 10-04-2006, 03:58 PM   #7 (permalink)
2004 HL Ltd. 4WD V6
View rayprog's Photo Gallery
I'm using it over a year ( for last 50,000 + km) for my Camry 92 v6. It shifts better and no complains/ already chaned it twice/
rayprog is offline   Reply With Quote
Uhhhh ? How do I check the tranny fluid level? Royalchoppers 2nd Generation (2005+) 14 05-06-2006 12:49 AM
Tranny fluid change? megamac83 Camry & Solara Lounge 17 04-11-2006 08:14 AM
95 camry auto tranny issues ziddey 3rd & 4th Generation (1992–1996 & 1997–2001) 0 04-08-2006 08:32 PM
Tranny Fluid luisitol Camry & Solara Lounge 30 04-06-2004 06:10 PM
Tranny question celica/camry Celica Forum 3 03-16-2003 09:37 PM
