Pool of Oil in spark plug cylinder - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2006, 09:12 AM   #1 (permalink)
megamac83's Avatar
View megamac83's Photo Gallery
Unhappy Pool of Oil in spark plug cylinder
Hey guys,
I recently changed my spark plugs and in one of my spark plug cylinders there was a pool of oil, I changed the plug and tightened a lil more. While it isn't pooling up, it still seems like there is a small amount of oil when I checked it again? I have already changed the valve cover gasket.
ANY IDEAS OF WHAT I NEED TO DO?
megamac83 is offline   Reply With Quote
Old 10-07-2006, 09:23 AM   #2 (permalink)
5SFE
Lord_Anarchy's Avatar
View Lord_Anarchy's Photo Gallery
VC gasket only? I had the same prob but with cylinder four only. Went ahead and searched my butt off only to find that simple spark plug tube seals are all that's needed. Replace the four rubber gasket rings around the spark plug tubes at the top (they are under each nut on the top of the engine, so it's four of them) and voila.. Oil gone!
Lord_Anarchy is offline   Reply With Quote
Old 10-07-2006, 09:25 AM   #3 (permalink)
View Ken4's Photo Gallery
Most likely your spark plug tubes need resealing. Common problem.
http://www.toyotanation.com/forum/t116299.html
Ken4 is offline   Reply With Quote
Old 10-07-2006, 09:40 AM   #4 (permalink)
megamac83's Avatar
YEAH I changed the Grommet, but I still see oil in the cylinder , I guess Ken4 is right I might have to get my the tubes resealed. Does anybody have any idea about how much that will cost?
Old 10-07-2006, 09:47 AM   #5 (permalink)
megamac83's Avatar
I don't know if this helps but sometimes I get blue smoke coming from the exhaust usually on cold start ups, could that also have anything to deal with this?
Old 10-07-2006, 10:39 AM   #6 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
In your case. Take the valve cover off & replace the doughnut shaped spark plug tube gasket. If you can't do that. Clean the gasket that's there well with isopropyl alcohol, or a little bit of acetone to remove the oil residue, run a bead of RTV around the gasket & replace it.
Don't drive it until sets (Read the directions).
White exhaust is just moisture evaporating in the exhaust.
Blue is generally a valve stem seal slowly leaking into a cylinder.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 10-07-2006, 10:41 AM   #7 (permalink)
View Isaac-1's Photo Gallery
I don't know about cost, but I did the job myself in well under an hour. I also changed the top tube gromets and valve cover gasket while I was at it. It seems like the gromets and gasket were under $30 together. I think the hardest part of the job was finding the right size wrench for removing the nuts at the top of the spark plug tubes. Otherwise it was simply loosen a couple of bolts a the top of the timing belt cover, remove the nuts on the top of the spark plug tubes, pull the valve cover off, and unscrew the spark plug tubes, one of mine was so loose I unscrewed it by hand, the other three I carefully used a vise grip on. Cleaned the old sealer off with a wire brush, spread a little oil resistant locktite on, and put everything back together.
Ike
Ike
Isaac-1 is offline   Reply With Quote
Old 10-07-2006, 11:18 AM   #8 (permalink)
View JPaganel's Photo Gallery
BTW, the wrench for the tube nuts is 30mm
JPaganel is offline   Reply With Quote
Old 10-07-2006, 02:35 PM   #9 (permalink)
View toyomoho's Photo Gallery
Blue smoke at cold start up could mean worn valve stem seals, or a malfunctioning cold start fuel injector. Next time it happens, smell the exhaust for gas or oil.
Old 10-08-2006, 12:55 AM   #10 (permalink)
dsm = desert sand mica.
View 94dsm's Photo Gallery
also check the spark plug cylinder wall, see if its cracked, i doubt it but my dad had an 88 celica 3sfe and that happened.
catbacked. miles keep pileing up quickkk!
94dsm is offline   Reply With Quote
Old 10-10-2006, 11:05 PM   #11 (permalink)
megamac83's Avatar
The Blue smoke happens every so often, not always on cold starts
Old 10-11-2006, 01:44 AM   #12 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
just do it yourself- on the 4 banger it's a cinche
HaHa
Old 10-11-2006, 06:49 AM   #13 (permalink)
megamac83's Avatar
wanna make a diy for it?
Old 10-11-2006, 06:54 AM   #14 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
that is fine.
it takes a few min for it to warm up and get the right mixture of gas-air
skewe is offline   Reply With Quote
Old 10-11-2006, 01:45 PM   #15 (permalink)
TN Pussy Man
sorry, my car's different....though it's almost the same thing
your best help would be the shop manual actually....they go through everything step-by-step with pictures and even torque numbers for all nuts/bolts
HaHa
Oil in spark plug hole?? WhiteTrash2775 Solara 5 04-26-2010 06:31 PM
funny oil change docktortal33 2nd Generation (2005+) 7 08-08-2006 03:17 PM
Oil on one spark plug bronzemaxell Camry & Solara Lounge 16 12-06-2004 09:08 PM
spark plug wires + spark plugs aleks77 Camry & Solara Lounge 4 09-13-2004 02:08 PM
Spark plug wire boot ']['R][) camry Camry & Solara Lounge 10 04-18-2004 12:59 AM
