Ceramic Pads or other ? Please help. - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2006, 01:26 PM   #16 (permalink)
View coquibone14's Photo Gallery
i currently have ythe metal composite ones silver brand from discount auto....the braking is decent but the dust created is tremendous and.....they sqqeal like a mofugguh
coquibone14 is offline   Reply With Quote
Old 10-20-2006, 02:19 PM   #17 (permalink)
View marc780's Photo Gallery
I doubt i will ever use ceramics, i dont think i need them for the type of driving i do. If you drive very hard with a lot of hard braking on hills, etc. then they are good because they will resist overheating better than the regular kind and maybe you should try them. But i know they are a harder material, wear the rotors faster, are likely to squeal, and also cost more.
Also i drive in southern california, where the driving conditions are usually either stop and go or freeway cruising and so ceramics offer me few advantages, and so i just use the regular type of brake pads.
Old 11-27-2006, 10:22 AM   #18 (permalink)
I'm Cam'd Up
Pimpinda93camry's Avatar
View Pimpinda93camry's Photo Gallery
I have silvers from fedarated and they squeak when they are cold but whenb the heat up they are fine....
but they do have a lot of brake dust. and it is harder to get off then the oem... i think i will go get new ones soon even though i just put htem brakes on.
****NEW 1970 CHEVY NOVA**** MORE INFO LATER
Cold Air Intake
Cat Back Muffler, 5% Semi Matelic Tint
16x7 Proline Alloy, Dunlop SP FM901 225/50/R16
Clarion HU, JL Slash 500/1 , 2 JL 10W0, Silver Star Headlights
Pimpinda93camry is offline   Reply With Quote
Old 11-27-2006, 12:58 PM   #19 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
Originally Posted by James100
I got the Duralast gold ceramic from Autozone for I think it was $32 for my friends car for the front. They have a lifetime guarantee for wear so when they wear down you just bring them back and you get new pads for free. As of yet they do not make any noise. Anyhow I figured I would give this a try because of the guarantee figuring also if they make noise or I have problems I would just bring them back and get a refund. Almost a no brainer.
I had read several post on here and thats why I got the Duralast rotors and pads from Autozone. If you dont like them you can just take them back. The rotors and pads were approx $92 for the front. Also make sure to take out the slide pins and clean and apply the silicone grease. 2 of the slide pins on this car were rusty.
They also come with the shims on the back to keep them quite. I did use a little sand paper on the end of one to make it fit better however.
Are you sure the lifetime warranty is for wear, or excessive wear due to manufacturer defect? Because, I've never had explained to me that when brake pads wear out (normal wear and tear) that you can just bring them in for a new set. Now, if they happen to come apart or are defective in some other way, I can understand that.
That'd be like anything thing else that is designed to wear down, like tires.
But, if that is the true case with those brake pads, check the fine print. I know that quite a few things with 'lifetime' warranties require that you replace other group-specific items or else the warranty is not honored, i.e. a fuel filter with a fuel pump, dryer and condenser with an ac compressor, etc. i wouldn't be surprised if when you took your worn out pads in for a new set that they ask if you replaced your rotors at the same time or something to that effect, which in your case you'd have that covered.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 11-27-2006, 02:10 PM   #20 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
OEM?
I thought the V6s came with ceramics as standard.
I even think I read it in the Toyota maint manual.
old faithful
amerikim is offline   Reply With Quote
Old 11-27-2006, 02:39 PM   #21 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Hawk HPS. been saying it for 3-4 years now. Best pads money can buy for this car by a *wide* margin!
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 11-27-2006, 09:49 PM   #22 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
v6's come with ceramics from toyota. good stuff.
i'd stick with ceramics if the car came with them.
nodrogkam is offline   Reply With Quote
Old 11-27-2006, 11:29 PM   #23 (permalink)
tC
View 95camguy's Photo Gallery
i put akebono ceramics all the way around on my 95 v6 and some of the benefits i had noticed over regular pads are less dust; less noise; and they seem to last longer than non ceramic pads. i put about 50k miles on a set of ceramics before i got rid of my camry and even after that many miles the pads still looked good.
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline   Reply With Quote
Old 11-28-2006, 12:03 AM   #24 (permalink)
nodrogkam's Avatar
akebono ftw. thats what i use.
Old 11-28-2006, 10:01 AM   #25 (permalink)
I'm Cam'd Up
I just went out to auto zone and bought some of there duralast golds.
I like them so far.
i got some of the duralast brake lube that the guy recomended.
put them on....
went for the test drive... NO Noise...good
a little bit of spongeness...bad
I was a little mad.... so i took it to my freinds house to get his opion.
He said to let the breaks bed in before judging.(since it is just around the corner)
I drove it some... did the proper bed in. (still in process since not engouh time).
got better each brake time i brake.
no noise and pretty good braking and low dust.
moral of the story is to get good breaks and dont be cheap.
Cold Air Intake
Old 11-28-2006, 11:07 AM   #26 (permalink)
Toysrme's Avatar
Cool
I ate up some of those crap Autozone Duralast pads in less than 10,000 miles. Front, and rear.
Now with Turbo!
Old 11-28-2006, 12:54 PM   #27 (permalink)
nodrogkam's Avatar
i installed the duralast gold ceramics on a friend's accord. he loves em.
haha hopefully the ceramics dont wear out at 10K...that'd be insane.
What brand ceramic pads are good? WhiteRabbit Camry & Solara Lounge 38 07-08-2006 02:25 AM
Any experience with NTB ceramic pads? uncle_bagley Camry & Solara Lounge 1 03-06-2006 07:05 PM
Should I do this or just change the pads? abimanyu Archived Corolla threads 2 09-27-2005 07:48 AM
Semi-metallic, or Ceramic pads?? rosco99 General Discussion 7 03-08-2005 08:31 AM
