Failed smog! Suggestions? 96 V6 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2006, 07:20 PM   #1 (permalink)
View pio!pio!'s Photo Gallery
3rd Generation Failed smog! Suggestions? 96 V6 Camry
Hydrocarbons were too high..the HC measured at 59..and 51 is the limit.
The car has a good cat..about 30000 miles old
The O2 sensors are only like 10000 miles old
what could I do to reduce HC to pass smog?
New plugs? plug wires? distributor?..just clean something or adjust something?
Thanks
pio!pio! is offline   Reply With Quote
Old 10-09-2006, 07:41 PM   #2 (permalink)
View SwampFox's Photo Gallery
How is your engine air cleaner? How many miles?
1994 Camry V6 SE Coupe
"Fall of the Republic" http://www.youtube.com/watch?v=VebOTc-7shU
SwampFox is offline   Reply With Quote
Old 10-09-2006, 11:37 PM   #3 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Hmmm....
Do 96's have 3 coils and wires?
My 95 has six coil packs, no wires, and no dizzy! Have you ever looked under the hood? Check and look/listen for vacuum leaks, cracked hoses, broken wires ect....
Pull the plugs and look. Make sure none are fouled and they all look the same.
Replace the Following:
Air filter
Plugs
Oil change
Fuel injector cleaner (add to gas) Chevron Techrolene is good.
Also, working the engine by pulling some semi steep hills while in the 5k rpm's will help loosen deposits. Most of the injector cleaners will need a couple tanks through to help you at all.
Test on DRY hot low humidity days, after sustained highway RPM.
Good Luck...
73...
73sport is offline   Reply With Quote
Old 10-09-2006, 11:53 PM   #4 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
When there is alot of unburnt fuel in the exhaust, it comes from too much fuel, or no/weak spark. (Fuel passed out of the cylinder into the exhaust.)
Start by checking spark. Ignition ends to fail before fuel in such a case.
Start with plugs. NGK or Denso ONLY I wrote my recommendations on it here.
DO NOT replace the wires with cheap crap. Simply put, if you're not paying roughly $100usd+ for a set of Toyota v6 plug wires.... It's cheap junk. Stick with OEM Denso, NGK, or real performance wires; Al-la Vitek / Magnacore.
Passed that. I would clean your MAF wire with a q-tip & some Isopropyl Alcohol.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 10-10-2006, 12:22 AM   #5 (permalink)
Gangsta SC400 & 5.7Tundra
iTrader Score: 35 reviews
View -SCWEET1-'s Photo Gallery
Damn Toys, you write it as if yu were a Mechanic.............. LOL!!!!!!!!!
-SCWEET1- is offline   Reply With Quote
Old 10-10-2006, 12:37 AM   #6 (permalink)
Toysrme's Avatar
Cool
Well... Sometimes I am a paid mechanic. I've been doing short-hand fill in work at one of the b'hams best indy domestic / jap shops for afew years. Spent a summer rebuilding transmissions a couple of years ago.
Got volumes of tech training books here from a tech school I never went too LoL!
All the autoshop101.pdf's everyone is always quoting from??? Yeah I recognized those along time ago. It's just the generic Toyota training manuals for years & years back.
Now with Turbo!
Old 10-10-2006, 01:51 AM   #7 (permalink)
View OEMonkey's Photo Gallery
Just get an oil change and make sure the vehicle is at operating temp before re-testing. A simple oil/filter change can easily lower your hc readings by 10ppm or more (depending on how diluted the crankcase is from blowby.) It will get it to passing levels but maybe not ave. readings for that yr/make/model. There maybe other maintenance issues you have to address.
OEMonkey is offline   Reply With Quote
Old 10-10-2006, 12:12 PM   #8 (permalink)
V8'sRGone
73sport's Avatar
Toysrme, vbmenu_register("postmenu_1453838", true);
I mention doing the injector cleaner and plugs for that same reason....
If the injectors are shooting a stream fluid verses a mist, the fuel will not atomize hence un-burned hydrocarbons in the quench area of the cylinder head being dumped into the exhaust and a failed test!
Getting a clean squirt (mist) from the injectors and a good hot spark will drop the hc's...
Personaly start low and work your way up $$$ ... start with a GOOD set of plugs an air filter to lean it out, and some injector cleaner.....
You have nothing to loose, however, buying new ciols and wires - may not solve the problem at all.
Just my 2 cents....
73...
Old 10-10-2006, 01:13 PM   #9 (permalink)
Toysrme's Avatar
Cool
I know why you said everything. I didn't contridict you in any way. No need to reiderate yourself.
I agree... Start cheap & go from there, which is why I suggest new plugs & general maintenance cleaning. Past that start fixing alot of things @ once b/c nobody in their right mind should want to deal with multiple CA emessions testing failures.
Seems brutal.
Now with Turbo!
Old 12-29-2006, 08:37 AM   #10 (permalink)
View acitydweller's Photo Gallery
sounds like you need a fundamental tune up.
93 Camry XLE V6
Original owner since 6 miles.
It has already outlasted 3 cars I've had.
acitydweller is offline   Reply With Quote
Old 01-01-2007, 09:48 AM   #11 (permalink)
The 6&amp;quot;4 Viking
Zandro's Avatar
View Zandro's Photo Gallery
High HC readings you say? checked the EGR system? you should also check if the ECU has registered any fault codes.
Zandro`s 09 Hilux 3.0 D4-D SR+
Zandro is offline   Reply With Quote
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 07:20 PM
Need suggestions on new Components for my 2000 camry v6 xxpanipuri 3rd & 4th Generation (1992–1996 & 1997–2001) 2 12-29-2004 05:43 PM
2002 camry V6 vs. 96 2dr camry V6 wheels17 5th & 6th Generation (2002-2006 & 2007-2011) 2 10-23-2004 11:59 PM
which magnaflow exhaust for 96 v6 camry robehsi 3rd & 4th Generation (1992–1996 & 1997–2001) 4 04-21-2004 05:59 PM
