sunroof type? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-11-2006, 08:00 PM   #1 (permalink)
View keithy's Photo Gallery
4th Generation sunroof type?
hello tn members,
My 98 camry's sunroof is leaking from the top. My plan was to take the sunroof off to clear the drain tubes. After reading through the gen 4 repair manual on sunroof, I found out that there are basically 2 different types of sunroof. tmc and tmmk made sunroof. what are the difference between the two different types? How can one tell the difference?
I went out to look at the sunroof on my car and the manufacture is "wabesto".
Is it even a stock sunroof? I do not know this because I bought my car used and would appreciate it if someone can help me out.
keithy is offline   Reply With Quote
Old 10-12-2006, 08:41 PM   #2 (permalink)
Camry Freak
98CamryLE's Avatar
View 98CamryLE's Photo Gallery
you can probably tell if it is factory if it has the following:
1) Somewhere on the sunroof glass it says something like "Toyota United" or something like that. (Just like on your windshield, side windows, and so on).
2) It has a factory control interface. (above the rearview mirror, along with a personal light. On the left side of the personal light should be the sunroof switch, on the right should be the light switch.-- and it all is part of the trim piece that holds your sunglasses or garage door opener)
If you don't have both of the following, you probably (although it's still possible) have either an aftermarket sunroof or one that was put in by the dealership when new. (Sometimes if the first owner wants a sunroof on a car that didn't come with one, they'll ask a local shop to put one in rather than order parts from the factory and do it themselves)
2007 Camry Hybrid
98CamryLE is offline   Reply With Quote
Old 10-12-2006, 09:41 PM   #3 (permalink)
the one I have got does not come with the map light assembly. but in the gen 4 repair manual, the one TMC make does not have the light assembly as well. Nothing that says "toyota" either. sigh ......... I am just confused. Thanks for your help though. I might just do "something" (no plans yet) to the sunroof seal and see if I can stop the leak.
Old 10-13-2006, 11:19 AM   #4 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
All TMMK Camry's start with 4 in the VIN.
"WABESTO" is an aftermarket sunroof. I'm not familiar with them.
There's a '77 MG with a wabesto sunroof for sale on ebay.
Maybe the glass is a wabesto replacement for the factory glass?
Sorry I can't help much. PM me with your email and I'll send you a Toyota PDF on the sunroof.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 10-13-2006, 03:26 PM   #5 (permalink)
On it's way.
SR5 Sunroof Fixed dirt666 Archived Corolla threads 20 08-20-2005 11:33 AM
SR5/GTS Sunroof assembly dirt666 Archived Corolla threads 1 07-05-2005 04:03 AM
The sunroof pop TSB toyota_tech_01 Scion Forum 4 11-05-2004 01:07 PM
Paseo sunroof neil Tercel, Paseo, Starlet, and Sera Forum 2 07-23-2003 06:35 AM
2003 Camry SE Type S in DVNLT Tubbyc 5th & 6th Generation (2002-2006 & 2007-2011) 1 04-04-2003 01:11 PM
