Cleaned throttle body now it wont start.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-12-2006, 09:45 PM   #1 (permalink)
View green94camry's Photo Gallery
Well I know It is because there is probably a pool of throttle body cleaner in the intake, I sprayed the throttle body butterfly until it was clean, probably should have done it with the engine running and revving but I didnt. Know it just cranks tries to catch and then just keeps cranking because at that point I think it starts to flood with fuel. I got it going and reved it to about 3K for a second by cranking it with the pedal to the floor to suck the fuel/throttle body cleaner out of the intake and it did start and rev and then I let off a bit and it stalled. I guess I'll have to wait until morning and hope all the cleaner and fuel evaporates. I was going to remove the throttle body so nothing would get into the lower intake but murphys law strikes again. Another fun day maintaining a camry
green94camry is offline   Reply With Quote
Old 10-12-2006, 09:57 PM   #2 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
^ Are you in Hartford, or the outskirts? starting Oct 23rd, I'll be at UHa 2 days a week for class if you need help with anything.
5 Lug Corolla WHAT?
Old 10-12-2006, 10:12 PM   #3 (permalink)
throttle body
Thanks I am in Boston. I appreciate the offer but I am jsut looking for feedback if it was a good idea to clean the throttle body that way or not. The spray I used is safe for sensors, so I guess I'll just have to wait until it has all evaporated in the morning. Hope it starts, I want to change my rear valve cover and spark plugs, but gotta get it started first. I guess I'd be more pissed if I HAD replaced the rear plugs removed the manifoled and replaced the valve cover gasket and have it not start LOL!!! I have alway s tried to only do one thing at a time that way you always know what helped, but I did the front plugs and cleanded the throttle body at the same time. I gues I should have done it with the engine running or the throttle body removed competely. Now all that residual crap has to dry up before it'll start.
Old 10-12-2006, 10:29 PM   #4 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
just hold the pedla down adn start it and keep it at like 2krpms for a little and it should be fine.
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 10-12-2006, 10:58 PM   #5 (permalink)
Thanks
Yup that did work for a second and I let off and it stalled, should work better tomorrow after everything evaporates. Thanks for the re-assurance.
I must say I have made a LOT of progress with the camry I cam close to selling it over the summer, but now it is in very good mechanical condition(once it starts again that is), so I'll be keepong it for awhile and saving a lot of money over buying a new car. I hadnt even been posting here for awhile-I sorta gave up on the car when the radiator started leaking and the struts were ratteling and the exuast was leaking, fixed all that in the past month and it rides and runs great. Forums like these are awesome resources. My haynes manual helped too
Old 10-13-2006, 01:23 AM   #6 (permalink)
View Ken4's Photo Gallery
Is yours using Map sensor or Maf sensor? For Maf sensor, you need to hook up your intake tract otherwise it will never start.
Ken4 is offline   Reply With Quote
Old 10-13-2006, 06:53 AM   #7 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
remove the air intake manifold so that it will evaporate faster
skewe is offline   Reply With Quote
Old 10-13-2006, 10:04 AM   #8 (permalink)
Gameroom cash: $303055
Do what RedPhoenix suggested. That's how you start a flooded engine. This time when it starts, let up on the pedal just enougn to keep the engine running. Don't overrev the engine. Just try to keep it running.
Mike
Old 10-13-2006, 11:55 AM   #9 (permalink)
Throttle body
Started up this morning, so everything is all set. Thanks for the replies. Seems to idle a bit better after cleaning but that could be from changing the front plugs too. At least I know its clean now.
Time to go to town on that stripped intake bolt and finish the spark plugs and rear valve cover.
Old 10-13-2006, 02:17 PM   #10 (permalink)
View leasaunce's Photo Gallery
thats normal, but i think you've sprayed in too much! hahaha....
next time yeah, just press on the accellerator and keep it around 2,000rpm for about 15-20sec and it should clear it up (it happened to me several months ago when i cleaned out the TB, wouldn't start for several times, but after idling the engine around 2,000rpm for 20sec problem solved)
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
Old 10-13-2006, 07:02 PM   #11 (permalink)
throttle body
Yeah I think you are right I sprayed in most of the can LOL!!! This really is something that is best done with the throttle body off the car or maybe even the entire upper air intake so you can clean that too; that way you can had dry everything and the cleaner will never make it into the cylinders. It flooded the intake pretty good. On carburated cars I would usually clean out the throttle bores with the motor running revving the engine as I sprayed the cleaner in. If I ever have to do it again I'll take the whole thing off.
Old 10-13-2006, 07:40 PM   #12 (permalink)
View marc780's Photo Gallery
yeah letting it pool up is not a great idea, in my post on this i point out, "spray and wipe the excess "
All that cleaner can flood the spark plugs and make em too wet to start. And can make the mixture too rich also. Thats why on the can they always say, "clean with a warm engine" and to start it right after cleaning, so you are starting a warm engine and not a cold one.
http://www.toyotanation.com/forum/t158097.html
Old 10-14-2006, 12:21 PM   #13 (permalink)
You might also want to check the oil for signs of contamination. Some of the excess cleaning fluid that can't be burned by the engine will make it's way past the pistion rings and eventually down in to the oil pan. If you haven't changed the oil recently, you might just want to do it as a precaution.
Mike
How to: Cleaning Throttle Body -4 Cylinder Engines- With Pictures marc780 3rd & 4th Generation (1992–1996 & 1997–2001) 95 04-06-2012 12:59 PM
Remote Start Help (Viper 160XV) LE05 Audio, Video, and Security - Tech 9 11-09-2006 03:26 PM
Cleaned Throttle Body....whats With The High Idle?? IvanHoe 1st & 2nd Generation (1983–1986 & 1987-1991) 15 08-15-2006 04:39 PM
Throttle Body Cleaning nobrainer Camry & Solara Lounge 13 06-29-2005 03:02 PM
