that's right, water is getting inside the passenger
door of my gen3
I've noticed this after raining lately, where i can actually hear the water sloshing around INSIDE the door (water isn't leaking inside the car, it's just inside the door).
So I unplugged the little plug at the bottom of the inner panel of the door, and let most of the water drain out.
After I drained the water out, I poured water around the door handle and door lock but no water got inside the door so water can't be getting in from there.
Next, I poured water around the window seal (bottom of the window, see pic) and there was definitely water leaking into the door because I could see water sloshing around as I moved the door.
pic:
http://img122.imageshack.us/my.php?i...scf1868ov2.jpg
I was wondering if there is any potential "fix" for this? Other than replacing the seal itself of course....maybe applying some sort of silicon to seal "the gap".....comparing the seal-to-window interface of the pass. door there appears to be more of a gap than that of the drivers side, but it could just be all in my head.
