How to reset Alarm on 93 camry after replacing battery? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2006, 12:55 AM   #1 (permalink)
View desi's Photo Gallery
3rd Generation How to reset Alarm on 93 camry after replacing battery?
Hi,
I just replaced the battery on my 93 camry's alarm. After changing the battery, the alarm does not work any more. I think that I need to reset the alarm, but I do not know how. The alarm key has two buttons (One is Lock/unlock Icon which is actually used to lock/unlock the car. The other button is "Option" which is not in use) I believe the alarm wires are under driver side panel. Two years ago a mechanic gave a new keyless entry remote and fixed it within 3 minutes. After I replaced the battery today the alarm stopped working. I just dont want to pay $60 to some mechanice to spend 5 minutes to reset the car alarm. Any detailed info on how to reset the alarm would be really appreciated. Thanks guys.
desi is offline   Reply With Quote
Old 10-24-2006, 11:03 AM   #2 (permalink)
View keithy's Photo Gallery
go to the FAQ section. your alarm should be the same as gen 4.
keithy is offline   Reply With Quote
Old 10-24-2006, 07:21 PM   #3 (permalink)
I figured it out. I could not find it on FAQs. Basically, you just have to download the PDF manual from manf. webiste and follow the directions. On my Camry I had audiovox PROOE2 remote control.
So the manual said.
Put the key in ignition and turn it to "On" position.
2.) Turn the valet swith (Driver side, near hood opener) "On and then Off then On then Off then On and then finally Off"
3.) You should hear the chirp noise
4.) Press and hold the lock/unlock button on your alarm till you hear long beep
5.) Turn Valet switch On and then Off again.
6.) Turn the key to off and remove
7.) It should program your remote
It took me about 15 minutes and about 4-5 tries. (I am not really good w/ cars)
You can just google your alarm's model # which should be on the back of alarm key.
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Disable '93 Camry Alarm? RMadness162 3rd & 4th Generation (1992–1996 & 1997–2001) 1 05-07-2006 10:11 PM
1993 Camry Factory Alarm Problem EngErnie 3rd & 4th Generation (1992–1996 & 1997–2001) 0 01-31-2005 01:17 PM
Alarm install on a 92 Camry, V6 maneesh Audio, Video, and Security - Tech 7 06-29-2004 02:55 PM
