On 2002-01-06 01:31, GreCam96 wrote:
I know i am new at this, but how do take apart the face dash of the radio inorder to get to the inside of the cigarette lighter.
Theres 2 screws that you have to remove then the panel just pops off. I think thats all there is to it (I forget). Can someone with a gen 3 verify this?
Also How can I splice the wire in my 4 neon lights to attach to the cigarette lighter?
I recommend that you use a 12V automotive relay. You'll use the +12V wire of the cigarette lighter to trigger the relay. Make sure that you verify this wire with a DMM before you splice into it.
This is the wiring info for the relay:
87 - +12V constant
87a - Not used
85 - Ground
86 - +12V wire from cigarette lighter
30 - Output to neons. Wire the positive wire of the neons to this.
You can switch 85 and 86 around. It doesn't matter as long as you don't wire ground and +12V to the same terminal.
Or is there another power source I can use that is safer?
It doesn't matter as long as you wire everything up correctly.
The +12V wire on the cigarette lighter is a switched source though. That wire only sees +12V when the ignition is on. So if you wire everything up like I said the neons will turn on whenever the ignition is on. If you want to be able to turn them on and off you can wire a SPST switch inline with the +12V of the neons.
Heres a diagram of the relay if you need it:
_________________
88 LE (Team C-Spec)
Team C-Spec & Team Quality Control - Master Technician
Powered By ? (Secret project in the works)
"Boost 0wNz j00!"
<font size=-1>[ This Message was edited by: 88 LE on 2002-01-06 08:12 ]</font>
