2000 Camry Trunk Tail Lights Not Functioning - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2006, 09:56 PM   #1 (permalink)
View ds_1910's Photo Gallery
4th Generation 2000 Camry Trunk Tail Lights Not Functioning
Has anyone resolved any issues with the Trunk Tail Lights not functioning? The Dash shows the rear light bulb out indicator when the headlights are on. The Brake Lights on the Trunk function OK / the tail light part of the bulbs do not light up. I have tried new bulbs and this has not resolved the issue. The outer tail lights (on left and right side of care) function OK it's just the inner tail lights on the trunk that are having a problem. Is there a fuse that would just control the trunk tail lights portion? All other lights on the car are functioning properly.
ds_1910 is offline   Reply With Quote
Old 10-26-2006, 10:06 PM   #2 (permalink)
Embrace the Suck
Edmo83's Avatar
iTrader Score: 8 reviews
View Edmo83's Photo Gallery
are you using the right bulbs? the bulbs for brakes/headlights (on) have two filaments....and two connections on the bottom...getting the wrong bulbs would prob cause the system to only use the light for brakes, not headlights on. make sure your bulbs have two connectors on the bottom.
if thats not the case...did you remember putting anything big in the trunk recently? maybe crushing or cutting a cable?
92 SC300 Garnet Red 5-speed 119k
01 Camry LE V6 Sailfin Blue 95K miles
Edmo83 is offline   Reply With Quote
Old 10-27-2006, 06:37 AM   #3 (permalink)
4th Generation
Thanks for your reply. I am using the 3157 Bulbs which have the dual filaments. I have also checked the wiring to see if there are any cut wires and there are none that I can see. I thought maybe there might be a relay or fuse that might be tied to the trunk tail lights. Any other ideas? Thanks.
Old 10-27-2006, 07:02 AM   #4 (permalink)
View kamrhee's Photo Gallery
4th Generation
Assuming everything checks out right (bulbs, fuse, etc.), check the wires inside the flex conduit cover running along side of the trunk hinge. I was having the same problem like yours and taillight indicator would come on and off until one day it just stayed on. Seems like the wires inside the conduit cover breaks from the constant opening and closing of the trunk.
Get some wire connector crimps (smallest ones), electrical tape and a sharp knife. Opening the cover, see if there are any wires that's broken into 2. Connect the wires using the connector crimps and it should be fine. Just wrap everything up and cover the flex conduit cover again with tape when you're done.
I guess the wire becomes brittle as it ages and the flexing of the trunk hinge doesn't help its condition. Hope this helps.
kamrhee
1998 Camry LE 5s-fe (Stock)
2002 Toyota Highlander 1mz-fe (Stock)
My other car is a Bianchi
kamrhee is offline   Reply With Quote
Old 10-27-2006, 04:34 PM   #5 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
could also be a relay i had this problem and my relay was broken and i had to get a new one
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 10-27-2006, 06:01 PM   #6 (permalink)
Every road's a playground
toyotaholic's Avatar
View toyotaholic's Photo Gallery
^ would this apply to the spoiler? mine doesnt work (sorry to steal the thread)
toyotaholic is offline   Reply With Quote
Old 10-27-2006, 06:47 PM   #7 (permalink)
4th Generation
Do you know where the relay is located and is this something that is easy to replace? Thanks for your reply.
Old 10-28-2006, 03:27 PM   #8 (permalink)
Go camry goooooo
DrewsCam's Avatar
im not actually positive, i had toyota do it, i beleive its behind the back seat in the trunk area, i really dont know its somewhere in that area
Old 10-28-2006, 07:02 PM   #9 (permalink)
4th Generation
Were all of the four tail lights out when you had this problem or were only the two trunk tail lights out?
Old 10-28-2006, 08:32 PM   #10 (permalink)
Go camry goooooo
DrewsCam's Avatar
all my tails, basically at night only my turn signals worked
Old 10-29-2006, 01:04 PM   #11 (permalink)
4th Generation
Ok thanks. I am having an issue where the outer tail lights work but the ones on the trunk lid do not. I suspect the relay would probably cause all of them to be out and not just half of them.
Old 03-27-2008, 01:16 PM   #12 (permalink)
View reyes13's Photo Gallery
hey, i've got the same problem. Is there a seperate fuse/relay for these running lights before I search all the wiring?
reyes13 is offline   Reply With Quote
Old 04-19-2008, 07:03 PM   #13 (permalink)
View chckmte's Photo Gallery
kamrhee
Thanks kamrhee, I was having the same issue with a 1999 Camry - found the broken wire and had it fixed in 5 minutes. Danny
chckmte is offline   Reply With Quote
2000 camry XLE PRD2L Lights by the shifter aleks77 3rd & 4th Generation (1992–1996 & 1997–2001) 12 05-12-2005 12:55 PM
99 Camry Tail lights xmakavell1 Camry & Solara Lounge 3 03-24-2004 08:56 PM
Clear tail lights for a gen 4 camry sedan Aussie Ed 3rd & 4th Generation (1992–1996 & 1997–2001) 27 09-23-2003 12:08 AM
