determining oil leak: valve cover or head gasket? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-27-2006, 08:15 PM   #1 (permalink)
View Camry LE 94's Photo Gallery
Exclamation determining oil leak: valve cover or head gasket?
i have an oil leak and I'm having trouble determining whether it's a head gasket or a valve cover leak... I am pretty sure it's a valve cover gasket leak but to be sure how could I tell?
Fixing the leak seems simple enough for me to do it, so I probably will attempt to. I've seen the pictures of that guy taking the valve cover off to paint it... yet I need to know what I should buy and where I should buy it from for that matter. Anybody know a little something about the problem I am having?
Camry LE 94 is offline   Reply With Quote
Old 10-27-2006, 08:32 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
you'll have to give a better description of your leak for us to determine
but check your oil and if it seems kind of milky, then it's a headgasket since it means you have coolant in it then.
and for a valve cover gasket, just pick it up from the dealer. it'll be about 20bucks.
HaHa
Old 10-27-2006, 08:41 PM   #3 (permalink)
3rd Generation
well the oil leaks closeby the valve cover and it's not milky... it leaks onto the front-end exhaust pipe, and when the car is hot, it creates a shitload of smoke, which comes out of my air vent and is very annoying/smells horrible. my friend took a look at it and saw fresh oil supposedly coming out of a bolt on the right side of the valve cover like 4 inches below it. other than that i dont know how much more I can describe it lol
Old 10-27-2006, 10:41 PM   #4 (permalink)
View AlphaMale's Photo Gallery
If Camry engines and under-hood electronics can take it, you might want to do an engine shampoo so when everything is clean, you can see where the source of the leak is better. It sounds like a valve cover gasket leak, which isn't a huge problem to remedy.
Alpha Male
1993 Nissan Maxima | 1998 Corolla
AlphaMale is offline   Reply With Quote
Old 10-27-2006, 10:46 PM   #5 (permalink)
Exclamation
thanks for the replies... where can i get an engine shampoo done?
Old 10-28-2006, 02:58 PM   #6 (permalink)
TN Pussy Man
that sounds like a valve cover gasket leak then- a pretty easy fix since it's in the front (I don't know if you have a 6 or a 4bnager).
and you can get engine degreaser/cleaner at your local automotive shop. just follow the instructions on the back of teh spray can.
you can try to cover your alternator and obviously exposed electrical connections and try not to soak those areas too much. otherwise, no worries about washing the enginebay
HaHa
Valve Cover Leak mchodan 3rd & 4th Generation (1992–1996 & 1997–2001) 9 09-05-2006 10:40 PM
Broke Valve Cover Gasket Bolt IN THE HEAD parimento1 1st Generation (1995-1999) 6 04-27-2006 08:38 PM
valve cover and oil pan 91RED3S MR2 Forum 4 04-10-2005 03:47 PM
Mobil1 5w-30 Synthetic and my 2002 Corolla??? gadawg Archived Corolla threads 6 01-26-2004 04:39 AM
Oil pan is off again! I need a leak proof gasket seal. Thoughts? bennington28 Hardcore Tech and Competition 2 01-25-2004 02:53 AM
