Springs & Struts Guide
^There's a little bit more information on comparing struts and such.
triggerhappy007, If your going with Eibach springs, you seem like you want to go into the performance area a bit more. I'd recommend going with Tokico Blues because their more stiff and would give you a better improvement especially with the Eibach springs.
I'm not too sure on replacing the bearings, but since your at it, you might as well. I think it's recommended to replace the inner bushings on the strut itself, but I forgot if the strut assembly comes with bushings or not.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
