99 Camry Power Steering Hesitation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-30-2006, 10:24 AM   #1 (permalink)
View vultrix's Photo Gallery
Canada 99 Camry Power Steering Hesitation
99 Camry 4Cyl 2.2L Sometimes when I slow down to take a turn my power steering seems to fail... I have to turn hard on the wheel and it only seems like it when I'm slowing in for turn and then its OK again??? Happens maybe for a couple seconds 1 o2 times a week and I drive everyday. No unusual sounds like belt slipping and belt looks ok! I did have a KROWN rust protection done and they spray everything around engine! Any ideas???
vultrix is offline   Reply With Quote
Old 11-11-2006, 08:30 PM   #2 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
Check belt tension and power-steering fluid level. If no problems are evident with these two things, report back for more ideas.
Good luck!
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
1991 I4 Camry power steering pump removal. mbp 1st & 2nd Generation (1983–1986 & 1987-1991) 11 05-12-2007 02:07 PM
99 Camry power mirror problem & others therealdeal74 3rd & 4th Generation (1992–1996 & 1997–2001) 2 09-18-2006 09:16 PM
1996 camry power steering help bp25 3rd & 4th Generation (1992–1996 & 1997–2001) 0 02-11-2006 08:20 PM
using Mobil 1 ATF as Power Steering Fluid for 2002 Camry 2002Camry 5th & 6th Generation (2002-2006 & 2007-2011) 0 05-12-2003 10:10 AM
