My 2000 camry V6 just started idling very rough this morning on my way to work.
It seems to be idle surging... Finally emmited a check engine light.
Before taking it to the dealer tomorow, I would like to know if there is a self diagnostic trick
that I can do to pull the code myself?
I know my old Talon I could turn the key to the on position and plug in an led into 2 pinouts on the harness under the dash and it would blink the code for you...
Does the 2000 Camry have a similar self diagnosis trick?
u could buy a computer....i have one and they r universal...great investment...i paid $160
2009 Camry SE V6 loaded
Mods: Borla Dual Exhaust with no resonator, K&N Intake, 5k HID headlights and 5k HID foglights, LED Tail lights, Complete interior leds, Ultra Racing Front Strut Bar, Ultra Racing 19mm rear sway bar, 20% tint, Rosen navigation system, 19 inch ASA GT1 wheels
The best bet would go to you local Sears adn buy there 69.00 dollar actron obd pocket scaner. That way you can pull the code write it down adn go to OBD-CODES.com adn find th Pxxxx nuber it will tell u what the code titile.
That way when you take it to the dealer you know exactly what code it is.
So say you have a p0708 code which is trans neutral senor voltage to high. which mosty likey be a bad ground, they cant say that the trans is burn't up and you need a new one. This can also be useful to test to see if the techincain is honest.
But when you read the code don't erase it or when you take it to them it might not show.
__________________ ****NEW 1970 CHEVY NOVA**** MORE INFO LATER
Cold Air Intake
Cat Back Muffler, 5% Semi Matelic Tint
16x7 Proline Alloy, Dunlop SP FM901 225/50/R16
Clarion HU, JL Slash 500/1 , 2 JL 10W0, Silver Star Headlights
yeah, like toyomoho said, both ODBII. you can rent and OBDII computer thing. 186.xx deposit itll pull the code and tell you what it means and also clear it for you. you can even do it in the parking lot and take it back in 5 minutes.
You gte owned then. My AutoZone comes out and does it for you.
My riced out crapmobile Camry: http://www.cardomain.com/ride/228043...y-xle-sedan-4d '96 Camry: 2MZ Supercharged.....
5 Lug Corolla WHAT?
On the 1996 Camry (ODBII), for both the I4 and V6 engine, cose P0110 is:
Intake Air Temp Circuit Malfunction
Open or Short in intake air temp sensor circuit
Right,
But what/where is the Intake Air Temp sensor?
This wouldn't be the MAF sensor would it? Because I just removed the MAF and sprayed it with electrnic cleaner and reassembled. Still no luck.
Morley, I'm personally not sure. Now that the code is here (I think the code is the same as the '00 Camry), someone is sure to post soon that will know better,
5 Lug Corolla WHAT?
