Hey all,
Had my engine and tranny out today. Seems my slight leak was due to the rear main seal I put in having a slight tear (didn't see it when I put it all together). Anyways, no leaks now , and that makes me a happy fellow
Anywho, while checking out other things, I noticed that the power steering belt has been rubbing on the timing cover, I can see the wear marks. I put the pump on and the belt before I dropped everything back in, and I can see how the top-over portion of the belt is just so ever slightly butting up next to the cover, while you can see daylight out of the bottom. I couldn't see anywhere that I could make an adjustment to the pump, and the cover is on tight. Could I be missing a needed shim on the ps pump pulley or something? I don't see it in the shop manual, so I doubt it. If anyone has any ideas what I could do, I'd greatly appreciate it.
