Another freakin problem, help!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2006, 05:58 PM   #1 (permalink)
abovethelaw's Avatar
View abovethelaw's Photo Gallery
I haven't even fixed the problem I have with the engine oil leaking and now I have another problem with this damn camry. Maybe they are related some how?
I started to notice this new problem a few weeks back and didn't really think much of it. At first I was thinking sludge build up in the engine. But the last few days the problem got nasty. The problem is, when I gently put my foot on the throttle pedal the car starts almost "jumping" like someone would press hard on the gas pedal and let go right away and again and again...it will jerk like that until I actually do press hard on the gas pedal and the car will start driving normally. It will jerk like 3-4 times and when I push the gas pedal harder it will drive. Also on turns sometimes the car BARELY rolls even if I'm pushing hard on the gas pedal. You can hear the engine going crazy but it wont speed up until I complete the turn....doesnt matter if I turn right or left.
So does this sound like a tranny problem or something else like throttle body? fuel pump?
I'm getting a new car in about 3 weeks but I still have to drive this camry to work every day and this problem is getting real bad. Any help is appreciated.
Thanks all.
abovethelaw is offline   Reply With Quote
Old 11-21-2006, 11:52 PM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
have you checked the tps?
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 11-22-2006, 03:14 PM   #3 (permalink)
I haven't had any time to mess with the cam yet...but the problem is getting real bad...its real bad especially in the beginning of the drive. Today in the morning I warmed up the car and had my foot on break and then put it into Drive and it did the jerked forward about 3-4 times(feels like if i was pressing the gas pedal hard for a split second and letting it go real quick) But once again after a few jerks by pressing the gas pedal harder the car will start going with no problem.
Old 11-22-2006, 03:21 PM   #4 (permalink)
MadDawg's Avatar
View MadDawg's Photo Gallery
could be fuel filter could be bad, cars can do amazing things when that isnt clean.
MadDawg is offline   Reply With Quote
Old 11-22-2006, 03:33 PM   #5 (permalink)
View davemac2's Photo Gallery
check your rubber air snorkle and vacuum hoses for leaks. If you have the V6, the rubber air intake snorkle gets brittle and develops cracks in the crevices which affects cold start performance like this at low speeds.
Other things:
Your TPS may have a dead spot.
davemc
davemac2 is offline   Reply With Quote
Old 11-25-2006, 09:26 PM   #6 (permalink)
View KieferS's Photo Gallery
Try cleaning the throttle body?
KieferS is offline   Reply With Quote
Old 11-25-2006, 10:54 PM   #7 (permalink)
View Novice_cardude's Photo Gallery
By this part of the description I would think a transmission problem. First off check the fluid level. If the engine is behaving normally and the car is simply jerking, it's a transmission problem. I don't think any engine trouble could transmit through a slushbox well enough to give the pulsing symptoms you're describing. ... Of course i never drive an auto so I really dont know...
But yeah the tps may be on the fritz as well. I'd check out the transmission first right now. Just check the dipstick when the car is cold... It's best to start the car, put your foot on the brake and work it through all the gears (leaving the car in gear for a few seconds) then turn it off and check the fluid. At least that's what i've heard. Like I said I got no experience with automatic transmissions, so anyone who does could probably tell you the correct way.
Good luck!
Novice_cardude is offline   Reply With Quote
Old 11-26-2006, 01:36 AM   #8 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
if youhace a 1mz then the problem might be the mass air flow sensor. does the engine bogg or shake violently?
V6LE_CAMRY is offline   Reply With Quote
Old 11-26-2006, 09:24 PM   #9 (permalink)
The engine sounds good and doesn't shake violently at all.
Old 11-26-2006, 09:54 PM   #10 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
Sounds like TPS... you can test it w/ a multimeter...
but if it has a dead spot you can't see it unless you hook it up to a lab scope...
bring it in to a shop
tHa kNiGHt FaLL is offline   Reply With Quote
problem with 5th gear (manual) afan Camry & Solara Lounge 6 11-21-2005 10:15 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 01:45 PM
QUICK SHIFTER/UNDER PANEL PROBLEM!! & DVD NAVIGATION??!! Rocness81 1st Generation (2003-2008) 6 12-09-2004 10:27 AM
87 Corolla hesitation problem. Bad_dude Archived Corolla threads 8 10-25-2004 04:31 PM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 01:33 PM
