New hubs necessary for drum to disk brake conversion? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2006, 10:34 PM   #1 (permalink)
View GameDay's Photo Gallery
4th Generation New hubs necessary for drum to disk brake conversion?
I've been reading a thread about the 4 cyl drum to V6 disk conversions...and I was wondering if I can keep the 4 cyl hubs, or do I have to use the v6 hubs?
Some say I can use the same...others say I have to swap to V6 hub. I'm guessing the V6 one is a little thicker in depth?
From what I've read..the primary item (wrecking yard) that I need are the calipers with pads, caliper mounting bracket, and parking brake lines? Will I need to pull the hubs too?
I was thinking I could buy new backing plates ($19.00), disks (26.00 napa), parking brake flex lines, and axle bearings.
Am I way off in my assessment?
Last, how can I tell my car was built in Japan or US? Do I have to pull the above from the a car (v6) built in the same country mine was built?
Thanks and God Bless!
Mike/GameDay
GameDay is offline   Reply With Quote
Old 11-28-2006, 11:07 PM   #2 (permalink)
Member
View triggerhappy007's Photo Gallery
Can't help you with the hub, but if your VIN starts with a J, it's Japan, if a 1, it's US.
97 Camry LE I4 - 06 GS300 rims (11/06), Tokico HP/H&R Springs(1/07), Pioneer 7400MP, Polk DB675, OSRAM Silverstars (3/07), K&N filter
triggerhappy007 is offline   Reply With Quote
Old 11-29-2006, 03:13 AM   #3 (permalink)
View toyomoho's Photo Gallery
The parts list for the Gen 3 has different numbers for the I4 and V6. You would also need a proportioning valve from a V6 rear disk car. What else don’t know? Check with an auto parts store either locally or on-line. See if they list a different part number for the I4 drum and V6 disk brake hubs.
Old 11-30-2006, 03:35 PM   #4 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Need rear hubs off a rear disk model.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
L.E.D. Tail/brake light & 3rd brake light conversion project eviltwin67 Camry & Solara Lounge 2 07-02-2003 10:24 AM
Brake Conversion UltraslowSolara Camry & Solara Lounge 4 03-19-2003 09:32 AM
Rear disk conversion for XR RAAMaudio 1st Generation (2003-2008) 5 06-21-2002 10:55 AM
drums to discs brake conversion sdsmene Camry & Solara Lounge 1 05-15-2002 06:41 PM
Rear Disc Brake Conversion ericlee303 Archived Corolla threads 0 03-03-2002 04:53 PM
