Bleeding Master Brake Cylinder HELP! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2006, 07:38 PM   #1 (permalink)
View Brujo's Photo Gallery
I need to replace the master cylinder and I don't know how to bleed it. I found this:
Bleeding Master Cylinder;
1. Disconnect the brake lines from the master cylinder.
2. slowly depress the brake pedal and hold it.
3. Block off the outer holes (should be two holes) with your fingers and release the brake pedal.
4. Repeat steps 2 and 3. Repeat 4 times.
It's a little vague and since I'm completely replacing it and want to do it right the first time. I ask for the help of the TN Camry gods please.
Got CAI? Check out my custom CAI! Click here
Brujo is offline   Reply With Quote
Old 12-02-2006, 07:51 PM   #2 (permalink)
View thisisntjoew's Photo Gallery
This is an example. You need to "recirculate" fuild through it before it is put back on the car. You insert a screwdriver where the pushrod goes and pump it. When it is "bench Bled you then bleed the entire system. by pumping to create pressure and then while holding the pedal down you open the bleeding screws on the caliper.
3rd Gen/5s-fe/Camry
thisisntjoew is offline   Reply With Quote
Old 12-02-2006, 08:39 PM   #3 (permalink)
Thanks!
Old 12-02-2006, 09:18 PM   #4 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
my friend helped me replaced the brake master cylinder on a 94 camry v6, i did not have access to bench bleed, so we use a poor man solution, just remove the old master cylinder, and put a new one in, and loose each inlet and outlet on the master cylinder at a time and let fluid out while one pumps the brake and monitor the fluid ensure it was bubble free, and keep pouring new brake fluid in the brake reservior. seem to be working for me, pretty sure it is not the profesional way to do.
bronzemaxell is offline   Reply With Quote
1995 Corolla 1.8 brake problems (master cylinder, booster, slave) danpass Archived Corolla threads 0 04-24-2006 06:12 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
Should I do this or just change the pads? abimanyu Archived Corolla threads 2 09-27-2005 07:48 AM
