92 Camry hood strut removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-03-2006, 12:47 PM   #1 (permalink)
View mlefebvre's Photo Gallery
I am trying to replace the hood struts on my 92 Camry but I can't get them off. I have read elsewhere that you "pop off" the strut from the ball joint, but nothing I do gets them free. I have tried pulling them, prying with a screwdriver (mostly ends up denting the underside of the hood) and twisting them off the ball which appears to be bending the ball shaft. The ball portion has a base on which I can fit a 12 mm wrench, but it does not move. Help!
mlefebvre is offline   Reply With Quote
Old 12-03-2006, 12:58 PM   #2 (permalink)
5S-FU
View Sniperdude's Photo Gallery
There is a little slot on the part where the strut connects to the chassis, and also where the strut connects to the hood.
If you stick a flat head into this slot (you need to use a little force), this tab will move backwards, and the strut can be pulled out.
Do the same for the side that connects to the hood.
Sniperdude is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
gen5 camry strut supdawg240 5th & 6th Generation (2002-2006 & 2007-2011) 7 02-09-2005 04:56 AM
4runner hood on a camry Meisner Camry & Solara Lounge 14 05-03-2004 12:34 PM
