Brakes??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2006, 10:18 AM   #1 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
3rd Generation Brakes???
Is there a usual time for the brakes to wear down???
How often should I change the brakes??
The reason I'm asking is because I had to replace my rotors, brakes, and the right axle not too long ago and I waited too late to change them before the situation got worse and it did anyway. I didn't hear any sqeaking or scrubing on the brakes; the only things I noticed were (1) I picked up a lot of brake dust in 2 days and (2) everytime I used the brakes the brake pedal and the steering wheel was shaking so bad that I thought the motor was going to fall out from under the car!!
JayMax03 is offline   Reply With Quote
Old 12-11-2006, 11:08 AM   #2 (permalink)
View popeye08's Photo Gallery
Your brake pad's materials is bad, it creates much heat to warp the rotor. You'd better change to ceramic, no dust smooth and quiet.
popeye08 is offline   Reply With Quote
Old 12-11-2006, 09:21 PM   #3 (permalink)
JayMax03's Avatar
is it better to go ceramic?
Old 12-11-2006, 09:59 PM   #4 (permalink)
Definetely, before you go to ceramic, change or resurface the rotor
Old 12-11-2006, 10:17 PM   #5 (permalink)
View toyomoho's Photo Gallery
Best to replace the rotors, as they tend to warp again if you just resurface them. Pay a little more for a quality rotor like Brembo
AE92 & AE82 Brake upgrade options.... freakinbox Older Generations (1969-1987) 8 09-13-2007 04:41 AM
1995 Camry LE Soft Brakes kentarver 3rd & 4th Generation (1992–1996 & 1997–2001) 14 10-17-2006 07:33 AM
Brakes, How are yours? Chazmanian 2nd Generation (2005+) 45 03-24-2006 04:18 AM
Changing Drum Brakes to Disk Brakes on 2003 LE DragonR6 5th & 6th Generation (2002-2006 & 2007-2011) 1 12-10-2004 05:07 PM
Conversion Kit - Rear Drum Brakes To Disc Brakes Nikolas Archived Corolla threads 5 08-20-2004 11:38 PM
