Trannie problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2006, 11:58 AM   #1 (permalink)
View brandon_a_boyer's Photo Gallery
3rd Generation Trannie problem
I have a 94 camry xle, the right around 25 and 45 it almost feels like the transmission is slipping, it will rev into high rpms, and then the gear will catch and the car will snap foward. Have any other gen three owners had this problem? Any easy solutions besides swapping out the transmission?
brandon_a_boyer is offline   Reply With Quote
Old 12-11-2006, 12:14 PM   #2 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
It does this all the time? Because my car and Im sure other camrys do that when they are not warmed up. But after wards, they work fine.
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 12-11-2006, 05:06 PM   #3 (permalink)
it does it on and off, its almost like the car goes into neutral
Old 12-11-2006, 05:45 PM   #4 (permalink)
View vwsteve's Photo Gallery
check out this thread and Dr J say that free reving is sigh of a trans goin bad...
Steve
http://www.toyotanation.com/forum/t150521.html
vwsteve is offline   Reply With Quote
Old 12-12-2006, 05:13 PM   #5 (permalink)
View tarbasd's Photo Gallery
3rd Generation
If it just that the transmission doesn't shift until high RPM, but the car pulls hard: that's normal for cold engine. If the car doesn't pull, but RPM jumps up, like in neutral, that's not normal and probably a bad sign.
I would check the tranny fluid level and quality and you can make a drain and refill - it is not harder than oil change.
tarbasd is offline   Reply With Quote
Old 12-12-2006, 06:19 PM   #6 (permalink)
Toyota Camry Vienta CSi
View Aussie_Camry's Photo Gallery
Thats good news for me... I always thought that my transmission was abit dodge, but it must be normal
As for the trans problem, I heard that one way to check if its slipping, like the above poster referred to in relation to if the car is pulling... is if the RPM's are rising but the speedo isnt, then its slipping.. or something like that
Aussie_Camry is offline   Reply With Quote
Electric problem! Please help!! 1987SR5 Pre-88 Toyota Pickup/Hilux 2 12-02-2005 10:58 AM
problem with 5th gear (manual) afan Camry & Solara Lounge 6 11-21-2005 11:15 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 02:45 PM
QUICK SHIFTER/UNDER PANEL PROBLEM!! & DVD NAVIGATION??!! Rocness81 1st Generation (2003-2008) 6 12-09-2004 11:27 AM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 02:33 PM
