New Alternator- Car wont start! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2006, 04:44 PM   #1 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
Ok, I just finished extending my battery wires, installed the optimas and hooked everything up and also did the big 3. The alarm works, the turn signals work but the car will NOT start. No clicks no whining nothing... The headlights also dont turn on. Also when i turn the key the only light i see is the little oil light.
Any thing that I may have missed? Helllllllllllllp
EDIT:
There is a single click noise from when i try to start is coming from one of the relays in the fuse/relay box.
Curry is offline   Reply With Quote
Old 12-11-2006, 06:19 PM   #2 (permalink)
Curry's Avatar
FIXED!
I found that two wires going from the fuse box were supposed to be spliced together, after doing that, started the car and BAM!!! CarPC which is running off my second battery worked like a charm! All my TV's lit up and voltage from the batter reading a sweet 12.08.
No lag while starting the car, Lights are not dimming no matter what i do! WOOOOOOOOOOO THE CAMRY IS BACK BABYYYYYYYY
Old 12-11-2006, 06:26 PM   #3 (permalink)
Moderator
eyeball96's Avatar
Gameroom cash: $797377
iTrader Score: 59 reviews
Congratulation! Doesn't it make you feel good when you figure shit like that out!! My wonderful "automotive dumb" daughter once called AAA, bc her car wouldn't start, she'd left it in "drive" when she turned it off....boy did she feel stupid!!
Old 12-11-2006, 07:10 PM   #4 (permalink)
Curry's Avatar
It felt great man, When my dad came home he asked me which shop did the alternator install and how much it ran, I told him I did it, he couldn't believe it. lol.
Old 12-11-2006, 08:06 PM   #5 (permalink)
Curry's Avatar
Oh damn. Ok so now it seems to be giving me trouble.
When I started the car I was getting around 12.59 Volts. With the car off I was getting around 12.20
My idle was completely normal.
After leaving it running for about 20 mins, I noticed that the voltage dropped to around 11.20 and then to 10.54
I took the car off and I got 9.63
Anyone know whats going on?
I ran 4 guage wire from the alt to the battery then I left the stock cable in place from the alt.
I then upgraded the chasis to ground to a 4 guage and took out the old one.
Then I ran a 0 guage cable from the first battery directly to the second battery and grounded it to the body....
EDIT:
Ok I left the car running, the idle is still normal but the voltage has now dropped to 7.64!
When i rev the car up a little the lights remain dim... From what I gather this sounds like the alternator isn't sending power to anything at all....
anyone else?
Old 12-11-2006, 08:45 PM   #6 (permalink)
Moderator
eyeball96's Avatar
I don't know shit about electrical systems in Camrys! I'll give ya tons of moral support! I'm sure someone here knows what going on tho!
Old 12-11-2006, 09:20 PM   #7 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
all that shit you got... Man I hope you don't blow yourself up!!!
JayMax03 is offline   Reply With Quote
Old 12-11-2006, 11:06 PM   #8 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
why hell would you put 2 yellow tops in a camry??? one yellow top should be plenty of power for the car..
i just got a yellow top and my cars light doesnt dim anymore starts a lot better etc...
i got a system and tvs too... ps2..
my car has around the same volts when on 12.20 - 12.59 Volts
then when i turn it off t goe to around 10.50 V
Old 12-11-2006, 11:19 PM   #9 (permalink)
Curry's Avatar
Can never have too much power my friend ; )
With the car started its supposed to read around 14.4
But I think it may be that the new pulley with the slack is causing me to have 12 instead of 14....
Old 12-11-2006, 11:41 PM   #10 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
Lightbulb
Originally Posted by Curry
EDIT:
anyone else?
I'd suspect the alternator or the wires/connections associated with the alternator.
Good luck!
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Old 12-11-2006, 11:53 PM   #11 (permalink)
Curry's Avatar
Well I think the problem has been discovered. Apparently this alternator needs a trigger wire attached to the harness for it to work. So I'm going to get right on that...
::crosses fingers::
Old 12-13-2006, 12:13 AM   #12 (permalink)
I work on euros.
View 96CamrySport's Photo Gallery
um...just so everyone knows...14.4 is normal running, 13.2-15.4v is normal charging voltages, 12.6 is standard fully charged battery, any less than that is considered discharged. if you're running less than 12.6, your alternator is not pushing enough electrons. check for voltage drops and such between the alt and batteries.
1996 Camry Sport (that's a DX Coupe with decals) with 186k
european cars are just like japanese cars, just heavier and more expensive.
7 ASE's.
96CamrySport is offline   Reply With Quote
Old 12-13-2006, 12:48 AM   #13 (permalink)
Curry's Avatar
Whoops forgot to post... The problem or at least what seems to be the problem is the trigger wire was never connected (didnt know I needed that) Which explains why the voltage slowly dropped to 7.6 while the car was running. The alternator was never really on. Tomorrow I will be hooking it up and testing my numbers.
Since we don't need two threads on this you can follow up and see my results in the audio/video section of the forums.
Thanks for all the suggestions and help!
2001 Tacoma won't start HotRodd38 1st Generation (1995.5–2004) 6 11-12-2007 04:44 PM
Start and go ? I don't think so. Mike-in-WV 1st Generation (1995.5–2004) 30 08-01-2006 09:51 PM
01 Rough Idle, Stall, Hard Cold Start anr 3rd & 4th Generation (1992–1996 & 1997–2001) 0 05-30-2005 01:50 AM
Click sound from under the hood..won't start snobdrblinkchik Camry & Solara Lounge 10 08-22-2004 10:04 PM
