Originally Posted by toyomoho
The wiper fuse is located behind the ash try on the driver’s far side of the dashboard. Right in front of where you left knee would be. For more details find the service info at the link below.
http://oregonstate.edu/~tongt/camry
I have a simlar problem on a 97 LE 4 cyl
Chilton manual shows a blue wire feeding to the pump & blue white leading away. The blue is fed through a fuse -- the same one as the wiper motor (wiper motor is OK). the blue white comes from the WF terminal on the wiper relay. I will look for power at the blue & ground the blue white to see if the pump runs bypassing the relay. Not even sure I can get to the pump i used -40 fluid so should not be frozen
