Transmission help!!! Gen 3 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2006, 10:07 PM   #1 (permalink)
web
View web's Photo Gallery
Just bought a '94 Camry SE for my daughter's first car. Everything was fine until this afternoon.
When I got off work and tried to drive home I couldn't get it out of park. The car will start and run fine but no amount of force will move the shifter (auto on the console).
I tried everything I could think of - engaged the park brake, got out and rocked it, pumped the brakes, pushed the ECT button (not really sure what that is) nothing.
Any ideas??? I bought it from a private seller, not a dealer, so I don't have a owner's manual.
Thanks all
web is offline   Reply With Quote
Old 12-11-2006, 10:20 PM   #2 (permalink)
Toyota..Moving Forward-->
djarno's Avatar
View djarno's Photo Gallery
Try removing the little black rectangle on the shifter(I believe it's the top left from the shifter) with a flathead screwdriver. Then try moving the shifter out of park.
'95 V6 Camry LE
'04 V8 Tundra
http://www.cardomain.com/ride/2305303
djarno is offline   Reply With Quote
Old 12-11-2006, 10:25 PM   #3 (permalink)
web
Is this the "shift release"? I saw a reference to it in another forum but searched the net with no luck. I'll give that a try in the morning.
Thanks!
Old 12-11-2006, 10:30 PM   #4 (permalink)
djarno's Avatar
Yep. It should let you manually move out the shifter, regardless of the brakes being pressed down or not. Hopefully the car will be running fine
'95 V6 Camry LE
'04 V8 Tundra
Old 12-12-2006, 04:46 PM   #5 (permalink)
View tarbasd's Photo Gallery
3rd Generation
Isn't there a "shift lock override button" on the shifter? Keep it pressed and move the shifter.
However, this only treats the symptoms. It would be nice to find what makes it stick.
tarbasd is offline   Reply With Quote
Old 12-12-2006, 05:27 PM   #6 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
did it do the trick or...is it still stuck?
It's interesting what could cause it to do that.
nodrogkam is offline   Reply With Quote
Old 12-12-2006, 05:27 PM   #7 (permalink)
View vwsteve's Photo Gallery
do your brake light work corectly cause it uses the same switch to allow it to come out of park, could be bad connection..
Steve
vwsteve is offline   Reply With Quote
Old 12-13-2006, 01:57 AM   #8 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
there also a small computer thing near the shifter that controlls it. if anything i have a extra from my car or you can get one from a junk yard.
^ and leaving it that way!
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-30-2008 12:33 AM
Transmission for 95 4runner w/90 engine Mallenski 4Runner Lounge 0 03-13-2006 12:55 PM
EYELIDS for a gen 3 or gen 3.5 camry??anyone seen them on a camry? TheGhostCamry 3rd & 4th Generation (1992–1996 & 1997–2001) 6 02-16-2006 02:57 PM
GEn 4 camry solars glow guages ona gen 4 reg camry mystickid 3rd & 4th Generation (1992–1996 & 1997–2001) 15 05-18-2005 06:06 PM
Transmission Flush Scare 03ESimposter Camry & Solara Lounge 14 12-07-2004 02:19 AM
