There is pwr steering fluid in my resorvoir - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-26-2006, 08:46 PM   #1 (permalink)
View machman's Photo Gallery
I noticed that my PWR steering fluid is low. I was going to fill it up with the specified Dextron III ATF fluid and noticed that the fluid in the resorvor is a brownish fluid instead of red. I can only assume the it is power steering fluid. I bought this car in Aug 04 and have put 40K(now has 129K) on it with no problems.
What should I do?
Thanks,
Ryan
machman
98 Camry LE V-6
machman is offline   Reply With Quote
Old 12-26-2006, 09:03 PM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $294873
View Buurin's Photo Gallery
What should I do?
Thanks,
Ryan
I say what the hell, just top it off with your ATF if it meets the requirements.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 12-26-2006, 10:47 PM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
If it is the original fluid from when the car is new, it is ATF without the red dye.
2007 Camry 2.4L 5M
Old 12-27-2006, 06:43 AM   #4 (permalink)
I am guessing that that is the case. The car has been very well taken care of. I will top it off with regular ATF.
Thanks a lot.
machman
98 Camry LE V-6
Old 12-27-2006, 08:11 AM   #5 (permalink)
seriousman's Avatar
View seriousman's Photo Gallery
Here's some important info that is written by my present employer "Lee Myles Transmission" It explains to you why a power steering flush is necessary-
"At one time or another, most drivers encounter a power steering problem with their car anything from fluid leaks or noise to stiff steering or hard turning after first starting the car. Normal driving eventually causes your power steering fluid to suffer from heat, friction and electrochemical degradation. The high pressure created when you hold hard turns is especially damaging.
Your power steering fluid, which starts out clear, eventually turns dark with age. Sludge and varnish deposits build up in your power steering system and prevent the easy turning and responsive handling you expect from your vehicle.
Our Power Steering Fluid Flush safely removes varnish and sludge deposits. It is also the best way to remove wear metals that slowly grind away your power steering's internal components, including the power steering hoses, power steering pump, rack and pinion and/or gear box. Our Power Steering Fluid Flush thoroughly cleans your vehicle's steering system and protects it with fresh power steering fluid and conditioners that revitalize the seals and 0rings."
seriousman is offline   Reply With Quote
Old 12-27-2006, 08:54 AM   #6 (permalink)
View acitydweller's Photo Gallery
i'd suggest looking into why the resevoir is low...
My 1993 Camry has had two flushes in its lifetime thus far and had never had to be topped off.
93 Camry XLE V6
Original owner since 6 miles.
It has already outlasted 3 cars I've had.
acitydweller is offline   Reply With Quote
Old 12-27-2006, 04:46 PM   #7 (permalink)
Flushing the ATF in the transmission isn't that difficult. Do a search and ken4 has a DIY posted. A link to it is probably in one of the stickies in the Camry forum.
2007 Camry 2.4L 5M
Old 12-28-2006, 08:07 AM   #8 (permalink)
Sounds like I may need to inspect for leaks. I am out of town at the time(didn't drive) but will check this out when I get back.
Thanks for all of the info.
machman
98 Camry LE V-6
Old 12-28-2006, 10:27 PM   #9 (permalink)
Sorry i might be missing the point but what does flushing the transmission fluid have to do with low power steering fluid levels?
93 Camry XLE V6
Old 12-28-2006, 10:40 PM   #10 (permalink)
Bah!!! Brain fart. I mean Ken4's DIY is for flushign the power steering!
2007 Camry 2.4L 5M
power steering fluid leak twocamrys Camry & Solara Lounge 10 03-24-2011 10:17 PM
power steering fluid change gen3 OMNI 3rd & 4th Generation (1992–1996 & 1997–2001) 3 01-12-2006 02:23 PM
power steering fluid change gen3 OMNI 3rd & 4th Generation (1992–1996 & 1997–2001) 0 01-11-2006 05:46 PM
Power steering noise after flushing/changing the steering fluid Camry 2001 Mark22 3rd & 4th Generation (1992–1996 & 1997–2001) 1 12-26-2005 12:34 PM
Transmission Flush Scare 03ESimposter Camry & Solara Lounge 14 12-07-2004 01:19 AM
