2000 Camry power window not working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-02-2007, 07:39 PM   #1 (permalink)
View shahid11's Photo Gallery
I have a 2000 Camry (V4). Recently, the rear right window stopped going up. After trying many times it moved up by an inch. It comes down easily but goes up only an inch at a time. If I try after 10 minutes it goes up by another inch.
Does anyone have any idea if it is a bad motor or the bad regulator? Switch seems to be O.K. since with both driver and passenger side switches I am observing the same behavior.
I am planning to purchase the required parts to fix it, but looking for detailed instructions to do it.
I will appreciate if any one can provide me help with this.
Thanks
shahid11 is offline   Reply With Quote
Old 01-02-2007, 08:29 PM   #2 (permalink)
nuchieboy's Avatar
Gameroom cash: $162049
View nuchieboy's Photo Gallery
4th Generation
try a loose or broken wire in between the doors..when u open the doors there should be a rubber boot....try to take that off or cut it and look for a broken wire
2009 Camry SE V6 loaded
Mods: Borla Dual Exhaust with no resonator, K&N Intake, 5k HID headlights and 5k HID foglights, LED Tail lights, Complete interior leds, Ultra Racing Front Strut Bar, Ultra Racing 19mm rear sway bar, 20% tint, Rosen navigation system, 19 inch ASA GT1 wheels
nuchieboy is offline   Reply With Quote
Old 01-02-2007, 10:17 PM   #3 (permalink)
View toyomoho's Photo Gallery
The link below provides access to Camry service manuals. Can you help the window go up by pulling on it as you push the switch?
http://oregonstate.edu/~tongt/camry
Old 01-03-2007, 08:04 AM   #4 (permalink)
Member
View triggerhappy007's Photo Gallery
So it can still go down at full speed? If so, I'm not sure. When my window could only go up and down an inch, I had to replace the motor/regulator since I bought it whole.
97 Camry LE I4 - 06 GS300 rims (11/06), Tokico HP/H&R Springs(1/07), Pioneer 7400MP, Polk DB675, OSRAM Silverstars (3/07), K&N filter
triggerhappy007 is offline   Reply With Quote
Old 01-04-2007, 09:31 PM   #5 (permalink)
View evident's Photo Gallery
I have this exact problem on my 96 camry. the driver side window goes down with no prob, but if i press automatic down or bring it down alot at a time, it only goes up incrementally, inch by inch.
evident is offline   Reply With Quote
Old 01-05-2007, 09:18 AM   #6 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
I'd pull the door panel and check the window for binding. If it's not that, then the internal magnetic reed switch that kills the power to the motor when it stops moving has failed. You could try to pull the motor apart and clean it. I've yet to do that successfully, but you may have better luck.
FWIW
YMMV
DFBonnett is offline   Reply With Quote
camry master power window switch and cost nobitanobi Camry & Solara Lounge 4 09-14-2005 10:18 PM
Making some cool power (caution! For reference use only ) AngryAE101 Archived Corolla threads 5 11-03-2003 11:03 PM
