high pressure oil cooler leaks after new gasket? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-02-2007, 08:42 PM   #1 (permalink)
View chicagocurtis's Photo Gallery
3rd Generation high pressure oil cooler leaks after new gasket?
Hi all, I've got a '95 camry I4 120k miles 5SE. Noticed a small oil leak from around block but always had enough oil in pan so didn't worry too much. Traced it to oil cooler. Went to dealership bought o-ring and gasket and put them in. Started engine to look for leaks. After about 20 seconds had a higher pressure leak from bottom of cooler. Thought gaskets might've been off so re-set them and cranked harder on retaining nut. Same thing: high pressure leak from bottom edge.
I checked out the spring loaded oil relief valve and it was toward the top of the holder. Is that normal or do i need to replace it? Or do i need to torque the crap out of retaining nut, which was on pretty tight to begin with, beyond how i found it in first place?
chicagocurtis is offline   Reply With Quote
Old 01-02-2007, 09:09 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $359260
iTrader Score: 13 reviews
how high pressure are we talking about? an actual spraying, or a fast leak?
check your gasket again...did you wet it with oil before replacement?
HaHa
Old 01-02-2007, 09:18 PM   #3 (permalink)
It was coming out fast not a spray but definitely under pressure. I seated it twice on the mount and looked around the perimeter to make sure gasket was on accurately so i'm guessing that's not the prob. Btw when i pulled the cooler off there was no sign of any of the two original gaskets/o-rings. I haven't come across a spec for how much to torque down the bolt so i'm guessing it's not critical the way a head gasket would be.
Old 01-02-2007, 11:29 PM   #4 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
What are you referring to oil cooler? Any pics? Just asking, I have a leak coming from the head gasket area.....
mandyfig is offline   Reply With Quote
Old 01-03-2007, 12:15 AM   #5 (permalink)
View toyomoho's Photo Gallery
Down load the service info for the 5-SFE engine from the link below. There is a small section on install/removing the oil cooler parts. There was something about using a rod to push on the relief valve and test it, it should move up and be spring loaded (push from the bottom/opposite end of the nut). The large nut/relief valve should be torqued to 58 ft-lbs
http://oregonstate.edu/~tongt/camry
Old 01-03-2007, 02:09 PM   #6 (permalink)
mandyfig's Avatar
I am looking the the manual, heck the Head gasket job is so intense, you have to tear the whole thing down..........maybe time to sell the GEN 3.......cry...cry...cry....
Old 01-04-2007, 01:24 AM   #7 (permalink)
thanks toyomoho. It's tough getting all info. you need. That puts me on right track
Old 01-04-2007, 05:58 PM   #8 (permalink)
mandyfig's Avatar
Head Gasket is a HUGE project and you need to be careful making sure you will not end up screwing up, instead of helping....
Old 01-14-2007, 10:18 AM   #9 (permalink)
mandyfig's Avatar
Leak coming from rear engine could be from power steering hoses, etc. Normally head gasket leak will leak out coolant....not oil, true?
Old 01-15-2007, 05:01 PM   #10 (permalink)
still leaking from oil cooler gasket
After resetting the o-ring on bottom of oil cooler and tightening to spec with torque wrench there was no leak. Also tightend spark plug nuts at this time.
Looked at oil cooler this morning and leak had come back. How can a leak come back after fixed? I have noticed vibrations in car after putting on new motor mounts. Could new motor mounts (not oem) be causing oil cooler gasket and spark plug nuts to shake loose? Is this small leak causing enough to jeopardize oil pressure and cause starvation to top end? Or do i let motor mounts "break in" and go from there?
Old 01-16-2007, 12:24 PM   #11 (permalink)
The I4 engine has always vibrated a little. Are you sure the oil is coming from the oil cooler setup? Did you torque the fitting down with a torque wrench to get the max squeeze?
When installing the spark plug nuts, continue to torque them down until the torque value stabilizes.
Old 01-16-2007, 12:52 PM   #12 (permalink)
i can see it slowly spurting from around the 11 o'clock area underneath oil cooler. I checked the spring thing in oil cooler relief and its good; torqued nut to 53 ft/lbs; and torqued spark plug nuts until all under spec. Like i said in earler post, i had the gasket on without leaks and it re-occurred. Is there a blockage upstream that's raising oil pressure at this weak point and causing leak or did gasket "sllip" and start leak again?
How much will this leak lower oil pressure? Enough to screw me or can i wait til weather gets a little better to deal with it? Thanks
Old 01-23-2007, 04:06 PM   #13 (permalink)
fixed oil cooler leak
After driving around for a week with a visible oil leak from oil cooler, i pulled it off the block and tried to get the relief hoses off as well. Those suckers won't budge even with liquid wrench on them. I thought about just cutting the lines and pulling it out to check bottom side of cooler but the prospect of putting new lines on seemed like too big a job. So, in the course of messing with it i found some of the original o-ring broken and crammed into bottom side of cooler. Pulled it out put new one on and so far so good.
I'm a bit of a noob so anyone who does this job make sure you pull old one out because it will not seat properly unless you do. Hope someone else can use this
Old 01-24-2007, 12:57 AM   #14 (permalink)
The old O-ring material sounds like the problem. This type of thing has happened to everyone at one time.
Oil filter relocation warning! jeffmazz 1st Generation (1995.5–2004) 12 02-19-2009 02:24 PM
oil cooler kj_mechanic 2nd Generation (2005+) 0 11-21-2006 10:34 PM
funny oil change docktortal33 2nd Generation (2005+) 7 08-08-2006 04:17 PM
Does the Oil Pan have a gasket? NickR Tercel, Paseo, Starlet, and Sera Forum 8 06-28-2006 09:55 AM
Low oil pressure after timing belt & oil pump seal change Hot66ss Camry & Solara Lounge 9 05-07-2006 09:44 AM
