how do you install spark plug tube seals? - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 7 Old 01-06-2007, 02:39 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I'm in the middle of changing the valve cover gaskets on my wife's 1997 V-6 Camry. After about 3 hours to get the upper intake off, the front valve cover came off easy of course. However, it doesn't appear that replacing the spark plug tube seals is a simple task. Am I wrong? What is the procedure? For that matter, there wasn't a drop of oil down any of the spark plug holes. Am I asking for trouble if I leave the old seals in and just put the new valve cover gasket in?
I tried for a little while to get the rear valve cover off but couldn't seem to get it off. Will it come off without having to remove one of the timing chain covers. That appears to be what might be holding it on.
Although we've loved our Camry, working on that engine is a total pain compared to the 3.5 liter inline six in my 1991 BMW 535i. For that matter, my 1986 Ford Tbird with 5.0 HO is even easier. I just want this to be done. Any help would be greatly appreciated.
Grace and peace,
Robert K
Robert K is offline
post #2 of 7 Old 01-06-2007, 03:05 AM
Quoted: 2 Post(s)
Download the Gen_4 service info for this engine at the link below. The tab needs to be force up then the gasket removed with pliers.
http://oregonstate.edu/~tongt/camry
toyomoho is offline
post #3 of 7 Old 01-06-2007, 03:58 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks a lot!
I have actually downloaded the entire manual for the car but missed the part about how to replace the seals. Trying to find what you want in those .pdf manuals can be difficult when you have to view them one page at a time. To be honest, I'm half considering just leaving the old ones in.
Thanks again!
Robert K
Robert K is offline
post #4 of 7 Old 01-06-2007, 01:34 PM
alotawatts's Avatar
Quoted: 1 Post(s)
Re: seals
How many miles on the car ?
I have not done mine yet but the seals on my Honda cover were a bitch to remove. Pick, chip, torch etc.
For my Honda I found out the aftermarket seals I had were lame....so consider buying genuine Toyota seals.
alotawatts is offline
post #5 of 7 Old 01-06-2007, 03:25 PM
TN Pussy Man
Eye8Pussies's Avatar
Quoted: 0 Post(s)
iTrader Score: 13 reviews
if your seals are fine- leave them
it's not worth the trouble unless you're getting oil in them. especiall since now that you've taken everything apart once, you'll be able to do it pretty easily next time (first time it took me 2 hours to take off my intake plenum. now, I can do it in about 10min).
as for the rear valve cover, you don't have to remove the timing chain cover, but you do have to remove the engine harness off the valve cover- which is the hardest part to do. It's even harder to put back on the same. I just cut off some of the mounting tabs
HaHa
Eye8Pussies is offline
post #6 of 7 Old 09-30-2009, 07:51 PM
Quoted: 0 Post(s)
Replacing and Installing spark plug tube seals on the 1mzfe, a tutorial..
After hours of frustrating seaches on google for how to deal with the PITA tube seals on the Toyota 1mzfe engine, I will share my new found knowledge for anyone stuck in the same nightmare scenario.
The primary issue with these suckers is that fact that they will likely be so degraded and literally melded to the metal walls of the valve cover that you will nearly go insane trying to figure it out.
Here goes,
After removing the valve cover, DO NOT make the mistake I did and start trying to scrape off to interior of the tube wall thinking you will get anywhere -- you won't. Here's the trick, leverage. Be aware that the tube seals are rubber flexible material in the middle, but are reinforced with steel around the outer edge even though they look like hard rubber/plastic -- they were probably installed with a massive press with extreme force from the factory, so they are now nearly fused with the valve cover.
The best tool I found was a tire tool that has the flat bladed end on it, they are an OEM tool with many cars - if you don't have one, then you will need a heavy duty long flat headed screw driver. With the valve cover upside down, look carefully in the tube holes and you will see a slight gap at the very bottom of the hole that my well look like metal that's part of the valve cover. It isn't. Wedge your flat blade at an angle up under this gap (you may have to hammer it in to get it to grab up under the metal) and then strong-arm your tool downward - lean into it and then let off a bit and repeat, sort of getting a torque effect. The metal ring will eventually dislodge from the tube holes, and voila, you have removed the tube seals.
Clean out the tube holes as well as you can , and get ready for the fun part. You will also notice some little metal tabs at the edge of each side of the tube holes, I'd suggest bending those upward as it helps a ton in keeping the new tube seals in place in order to press them in. Place a new tube seal in the hole (the orientation of the new seals will be raised edge up where as you could insert a 30mm socket into them, which is one way to beat them in). I used a 33 mm socket, which would be a standard axle spindle nut socket - if you don't have one then you will have to improvise with a piece of wood and go from there to get them as far in the holes as you can. Place the socket open side down lined up with edge of the ridge of the new seals - get a solid piece of wood (so you don't break your sockets), place it firmly onto the top of said socket, take your hammer and beat it as hard as you can with precisive blows to keep the pressure as even as you can -- don't hold back, these suckers take massive force to get them pressed in correctly. If you are worried about leakage, then coat the seals with high temp RTV before installing and around the top edge after they've been beaten in. That's it!!! Enjoy!
pdiggity is offline
post #7 of 7 Old 10-06-2009, 02:52 PM
Quoted: 0 Post(s)
another way to get seals out
I used a cold chisel to cut the side of the seal next to the valve cover. Once it was cut most of the way through, I was able to bend part of it out of the way enough to grab it with vice grips. A few wiggles and it all came free.
phbrown is offline
User Tag List
Linear Mode Linear Mode
« Back
