Fuel Pump Install- Leaking Fumes?
This is a question to people who have installed fuel pumps before...
I recently installed my 255lph fuel pump.
Originally, I had reused my old fuel pump bracket gasket and I also lost a screw by accident, so I got a strong fuel smell in my car since I presumed that the fuel pump bracket didn't seal right, so I picked up new screws and a new gasket and reinstalled them.
I'm not sure if it's just my imagination, but I think that I still smell the fuel- though there is probably some residual fuel in my backseat since I spilled some when pulling the pump, though I tried my best to clean it up.
Also though, when removing the original pump, I wasn't able to undo the bolts that held the out-flowing fuel line in place (the semi-hard line), so I cut it instead and after installing my new pump (which came with a bracket), I used clamps to hold a fuel hose between the original hard line on the car and the new bracket. In short, there are no leaks and pressure should be good.
Have I fogotten anything else to do, or is there any possibility that there are fumes coming from elsewhere? There is no smell from outside the car (that I can tell of), and it just seems to be the inside.
Or maybe I'm just paranoid and should just wait a couple days and see if the smell goes away...
Any ideas would be appreciated
HaHa
