NGK Wires - Page 3 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-25-2007, 04:27 PM   #31 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
thanks once again to everyone.
my wires touch in two locations (these wires are slightly longer than factory), that shouldnt be a problem as they are insulated right?
I've driven it and it drives flawlessly. Probably just mental but it feels like its more powerful and responsive (im sure its just mental..lol).
Here are some pictures after i finished. I did loose a plastic piece that kept the wires separate near the rear of the engine but i think things will be okay without it. It fell somewhere down by my steering rods - i tried to get it out by going over speed bumps gas/brake but it doesnt work, and i can't even see it.
nodrogkam is offline   Reply With Quote
Old 01-26-2007, 12:55 AM   #32 (permalink)
Green Gang
View 213solider's Photo Gallery
what type of spark plug did u use?? double or single tip
Camry TRD
213solider is offline   Reply With Quote
Old 01-26-2007, 03:02 AM   #33 (permalink)
nodrogkam's Avatar
i stick with oem replacement denso double tip plat.
Old 01-26-2007, 09:39 AM   #34 (permalink)
Green Gang
how much was it?
Camry TRD
Old 01-26-2007, 11:01 AM   #35 (permalink)
nodrogkam's Avatar
the plugs? it varies where you get yours.
i got my plugs a few months ago at autozone. I forgot how much...around 7 bucks a pop?
www.sparkplugs.com can give you an idea.
Old 01-26-2007, 11:56 AM   #36 (permalink)
alotawatts's Avatar
View alotawatts's Photo Gallery
May be a nit but I think you want to avoid wires contacting. A contact like + is okay but two or more parallel could give you grief. Looking at your pics I would think you could get all of the wires on the same side of the coolant cap and use seperator clips........ ?
alotawatts is offline   Reply With Quote
Old 01-26-2007, 02:45 PM   #37 (permalink)
nodrogkam's Avatar
well i wish i didnt loose the big separator clip, but i did. So far no issues though.
Old 01-26-2007, 03:18 PM   #38 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
You can get seperators at car parts store fo just about $3, be sure that they fit smallre 6mm wires
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 01-26-2007, 03:33 PM   #39 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
effing coil packs...why do they use coil packs?
Get's rid of the dist. Which means less resistance.
Also less maintenance [no cap/rotor to replace].
Packaging them on the engine is more space efficient and also shortens the spark path [not really anything as electricity moves at the speed of light].
Originally Posted by Eye8Pussies
from the shop manual, the firing order should be like this:
Rear -> 1-3-5
Front -> 2-4-6
That is actually the cylinder arangement.
The firing order is
123456
FYI bank 1 is the rear bank [135] and bank 2 would be the front bank [246].
92 Alltrac, 85 PU
alltracman78 is offline   Reply With Quote
NGK wires question WhiteRabbit Camry & Solara Lounge 2 03-08-2006 08:03 PM
NGK Wires Dolanite Tercel, Paseo, Starlet, and Sera Forum 3 09-01-2005 03:02 PM
