pulling engine (5sfe) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-17-2003, 09:06 PM   #1 (permalink)
View 2drcam's Photo Gallery
has anyone ever pulled this kind of motor. reason being is I want to know if it's easier to pull the whole motor with the tranny or leave the tranny in the car??? it's auto
so give me some input...thanks
2drcam is offline   Reply With Quote
Old 06-17-2003, 09:43 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: pulling engine (5sfe)
My buddy and I pulled a 5S-FE out of his 94 Camry 2 weeks ago.
Its easier to pull the engine with the tranny.
You could unbolt the tranny from the engine and support it with a tranny jack or whatever, but goodluck getting the engine and tranny to line backup when you bolt it back together.
"Skoolin' the unlearned!"
Old 06-18-2003, 08:53 AM   #3 (permalink)
alright thanks bro...that's all i need to know
Old 06-18-2003, 02:25 PM   #4 (permalink)
View Meisner's Photo Gallery
Re: Re: pulling engine (5sfe)
Actually I did it twice where I left the tranny in the car...it wasn't all that bad lining it back up again. It's a lot easier with a engine level adjuster.
I am about to pull just the tranny out of a Corolla...this should be fun!
Steve
1996 Turbocharged Camry 5S-FE (4 cyl)
http://www.meisners.net/camry
Meisner is offline   Reply With Quote
Old 06-18-2003, 03:35 PM   #5 (permalink)
3s-fte power!
djprefix's Avatar
View djprefix's Photo Gallery
Yea, easier to pull it with the tranny.
My favorite method of lining them back up is to have my friend hold the transmission in his lap while we tilt the motor down into him
3S-FTE: 9.3:1 compression + 5psi = owns you!
djprefix is offline   Reply With Quote
Old 06-18-2003, 03:57 PM   #6 (permalink)
Re: Re: Re: pulling engine (5sfe)
Oh that sounds like fun! He must be a good friend or not be a friend anymore!!
What do you normally do to change the clutch? You don't pull the engine for that, right?
Old 06-18-2003, 06:27 PM   #7 (permalink)
3s-fte power!
djprefix's Avatar
Re: Re: Re: Re: pulling engine (5sfe)
Just drop the tranny, a lot easier that way.
Old 06-22-2003, 05:45 PM   #8 (permalink)
ok...the motor is out, tranny is off, now the bell housing is a bitch..
how can i take this thing off, is it held on by bolts or does it have to be pulled off???
somebody PLEASE help...it has been holding me up sooooo long
thanks
Old 06-22-2003, 09:23 PM   #9 (permalink)
BangBangBang do dat Thang
S.Thet's Avatar
View S.Thet's Photo Gallery
somebody help him!!! just trying to help get somebody to give you info
S.Thet is offline   Reply With Quote
Old 06-22-2003, 09:42 PM   #10 (permalink)
Grenaded piston
88 LE's Avatar
Something doesn't make sense here. If the bell housing is still attached to the motor that means you haven't taken the tranny off yet.
The bell housing is part of the tranny.
1. Remove all the bolts holding the tranny to the motor (block).
2. Theres a access plate on the bottom of the tranny held on with 3 or 4 little bolts.
3. After you remove the access plate you need to unbolt the torque converter from the flex plate. Theres 6 or 8 bolts (I forget).
4. Then you can seperate the tranny from the motor. You might have to pry in between the 2 to get it seperated.
