White smoke on startup, then disappears - head gasket? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-12-2007, 03:12 PM   #1 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
I took my mom's car to my cousin's house for an oil change and when she pulled up in front of me to switch cars, I noticed white smoke coming out of her exhaust. The car had been sitting for 24 hours. The smoke goes away after a minute or two and does not come back when the engine is warm, and it does not get worse if revved when warm.
Important info:
- 1995 1MZ-FE w/ 78K miles
- White smoke on start up when engine is cold (ambient temp is 75 degrees)
- Disappears in a minute or two
- No white smoke when engine is warm, and if warm, does not get worse when revved
- Haven't checked the coolant level, but no overheating [temp needle stays just below the middle mark]
- There's a new 'old car noise'; nothing loud or horrible sounding but before all you could hear was a slight whistling/whirring sound when the car was on which actually sounded neat - now you can hear some kind of mechanical noise. Doesn't get louder when revved..it's just constant. I thought of this when I saw a gen 1.5 ES300 the other week and you couldn't even tell it was on as it creeped by.
My cousin said it could be a blown head gasket, and he's going to test it later. Something about using his air compressor to test it.. Anyway, I've been searching TN and the internet, and it seems some people say any white smoke on start up is bad (cuz coolant collected while sitting overnight) while others say if it disappears after a brief moment, it's normal.
Thoughts?
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 02-12-2007, 04:18 PM   #2 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Must be since your in Hawaii, but around here in the winter pretty much every car has white smoke that comes out, even after being driven for a while.
Does it look like this?
geoff5093 is offline   Reply With Quote
Old 02-12-2007, 04:39 PM   #3 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
I AGREE ^^^^^^^^^
i have the same smoke on start up then then goes away after a while.. OR will still if its real cold out
Old 02-12-2007, 04:49 PM   #4 (permalink)
In comparison to that Subaru station wagon, I'd say my mom's car has about 1/3 the amount coming out. It's not real thick - it's fairly transparent.
moving forward
Old 02-12-2007, 04:53 PM   #5 (permalink)
geoff5093's Avatar
Ya that car has alot coming out, but around here that is perfectly normal, especially during the winter. Im sure its nothing to worry about.
Old 02-12-2007, 04:53 PM   #6 (permalink)
aussie_gen1's Avatar
View aussie_gen1's Photo Gallery
Sounds like oil leaking into the cylinders thru the valve stem seals, between the valves and valve guides, from the top of the engine, when left sitting for a while. If it bothers you, get a leakdown test, i think it's called, to test the integrity of the valve stem seals.
It doesn't sound too harmful for the engine, but will use a little oil and annoy you.
aussie_gen1 is offline   Reply With Quote
Old 02-12-2007, 06:02 PM   #7 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
if its white and only lasts a min. or 2, its usually just condensation in the exhaust, collected as it cooled. if its white-water (also if you smell it, and it smells sweet its coolant), blue-oil, black-running rich, and finally white/grey puffy-then you have an injector on constantly, causing unburnt fuel to exit the exhaust, but ive only seen that once.
keep an eye on your coolant level, check your oil to see if its foamy after driving, if you get foam-headgasket is dead.
it could be the valve seals, but its not gonna hurt anything...i only see that mine are leaking after its been sitting for awhile, i start it, and revv it.
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 02-13-2007, 10:25 AM   #8 (permalink)
alotawatts's Avatar
View alotawatts's Photo Gallery
Smoke or Steam ?
Is it smoke or steam ?
Constant steam would be headgasket
04 Highlander 01 4Runner 00 Camry 90 Chev S10
alotawatts is offline   Reply With Quote
Old 02-13-2007, 10:40 AM   #9 (permalink)
View marc780's Photo Gallery
It's normal. water vapor always condenses inside the exhaust system at night. Then puffs out some for a little while until the exhaust system gets hot and blows it out.
Old 02-13-2007, 01:37 PM   #10 (permalink)
View DoubleEdgedWomb's Photo Gallery
During the cold times of the year, every car I've ever driven has done that. Surely they can't all have had bad head gaskets.
DoubleEdgedWomb is offline   Reply With Quote
Old 02-13-2007, 01:56 PM   #11 (permalink)
View mike7869's Photo Gallery
that car should not do that where its warm.. but i had the same problem with mine.. you can tell the difference between steam and white smoke.. that smoke is thiker. and does not fade as fast.. but does it when ever it wants.. and it goes away after a second or 2, and im not leaking oil. with a head gasket tho, u will keep having the white smoke and it won't go away.. you can also look in you oil to see if there is coolent..
mike7869 is offline   Reply With Quote
Old 02-13-2007, 08:04 PM   #12 (permalink)
Toyota Camry Vienta CSi
View Aussie_Camry's Photo Gallery
Yeah thats just normal mate... I got alittle worried by it to in my first winter owning a car after hearing about white smoke being bad, but it isnt the headgasket, that would be a constant amount of smoke. And if your coolant level isnt going down (dont think you mentioned?) then its defintely not the head gasket
Aussie_Camry is offline   Reply With Quote
Old 02-13-2007, 09:35 PM   #13 (permalink)
View toyomoho's Photo Gallery
Take a whiff of the whatever is coming out; you will know if it is water vapor or coolant. If oil could be worn valve stem seals. If water could be condensation. If coolant, the coolant level will drop over time. If you are worried about a blown head gasket have the coolant tested for exhaust gases and system pressure tested. Both are simple tests.
Old 02-16-2007, 07:42 PM   #14 (permalink)
Thanks. Will do that tomorrow when I detail the car; there is zero white smoke unless the car has been sitting overnight. I appreciate everyone's help and input. My mom's Camry only has 78K miles and I honestly expect it to go another 10 years no problem.
moving forward
Old 02-16-2007, 08:41 PM   #15 (permalink)
iTrader Score: 6 reviews
View Trdkamuri510's Photo Gallery
despite what everyone else says i can tell you its the valve stem seals.. if you look closely the white smoke is actually blue.. that is oil burning.. as others have said. it gets past the valve seals into the cylinder.. then when startup after sitting, it burns off.. hence the smoke.
its not a blown head gasket. its not water vapor cause i can garuntee u it will happen even when its 100 degrees out.
sittin pretty wid a lil wide ass
Trdkamuri510 is offline   Reply With Quote
Another head gasket thread pt. 3 buffalo86 Pre-88 Toyota Pickup/Hilux 0 12-01-2006 09:14 PM
New Toyota Head Gasket, no more leaks!!! reezytercel Tercel, Paseo, Starlet, and Sera Forum 1 03-06-2006 09:05 PM
Head gasket theory needed peterng 89-95 Toyota Pickup/Hilux 4 01-15-2006 09:51 PM
5sfte.... blown head gasket??? urbandork Celica Forum 7 11-11-2005 05:07 AM
Head gasket blew...need advice ryde MR2 Forum 2 10-28-2005 09:22 AM
