Cooling fan problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2007, 08:32 AM   #1 (permalink)
View szalex's Photo Gallery
Cooling fan problem
i have a 93 camry,this days when i start the engine in the morning,despite the low temperature ,the cooling fan turns at high speed,i don't know how i can do?
szalex is offline   Reply With Quote
Old 02-14-2007, 06:40 PM   #2 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
...do you have your A/C, or defroster on? if so, thats why.
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 02-14-2007, 07:57 PM   #3 (permalink)
someone told me that it's because "faulty coolant temp switch",suggest to "disconnect temp switch connector and bridge connector",but i don't know where the "coolant temp switch" is?would you tell me its exactly place please? my a/c is off.
thanks!
Old 02-14-2007, 08:34 PM   #4 (permalink)
Axel Kain's Avatar
what motor, what fan? electric or hydrhaulic?
Old 02-15-2007, 01:48 AM   #5 (permalink)
sorry,my car is 93' camry3.0 v6xle with 3vz-fe engine,hydraulic fan.thanks!
Old 02-15-2007, 05:13 PM   #6 (permalink)
Axel Kain's Avatar
check haynes manual pg. 3-6, it says to jump terminals E1, and OP1 - fan should run at 1100 rpm. its prolly best if you check a haynes manual. the coolant temp wensor id the only sensor the ecu uses. (the fan is controlled by the ecu)
Old 02-15-2007, 07:44 PM   #7 (permalink)
But i don't know where to get a "haynes manual",i bought this second hand car,without any user manual,and in our country,this kind of manual is very difficult to find.i have send it to several repairs but always gave me a wrong judge,they didn't know where the unit is on,what function it has...,money spend but the faulty still..
Old 02-16-2007, 08:36 AM   #8 (permalink)
2004 HL Ltd. 4WD V6
View rayprog's Photo Gallery
This kind of book never came with car.
you could get it at amazon:
http://www.amazon.com/Toyota-Camry-A...e=UTF8&s=books
or search on e-bay:
ISBN: 1563921448
rayprog is offline   Reply With Quote
Old 04-08-2007, 08:05 PM   #9 (permalink)
View pigpig's Photo Gallery
szalex,
i have a 2000 camry le, i have the same problem as yours.
do you still need help?
pigpig is offline   Reply With Quote
Old 04-09-2007, 10:40 AM   #10 (permalink)
sure,pigpig,i need your help very mach,thanks
Old 04-24-2007, 02:19 PM   #11 (permalink)
szalex,
sorry it took a while for me to get back to you. again, this is from my 2000 camry LE I4, things may be different on your camry.
here is the check list:
1. coolant temp sensor.
2. engine fan relay.
i will post some pic when i get home for 1 and 2.
Cooling Problem.. jnight666 Pre-88 Toyota Pickup/Hilux 11 12-05-2006 07:41 PM
2006 Chart: Recall woes grip Toyota fargoal Toyota News 30 07-25-2006 11:14 AM
cooling fan trouble pinoyboi2006 MR2 Forum 6 04-20-2006 10:00 PM
cooling fan on all the time newbi Archived Corolla threads 15 04-27-2004 09:14 PM
Oil cooling problem!! Kaz Tuning Archived Corolla threads 8 11-25-2002 11:55 PM
