EGR Malfunction - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-15-2007, 09:51 PM   #1 (permalink)
Orezok
View orezok's Photo Gallery
4th Generation EGR Malfunction
2000 camry 4 cyl 150K miles. The engines started pinging recently, not only under load, but on level roads at 75, NOT an octane issue- already tried that. No MIL codes.
Determined that EGR system is not functioning properly. EGR valve, vacuum modulator, vacuum switching valve and hoses all check OK per factory manual tests.
Found that VSV is receiving 12v at all times. It should de-energize at high RPM to allow full vacuum to EGR valve.
Bad ECU or?
orezok is offline   Reply With Quote
Old 02-16-2007, 09:59 AM   #2 (permalink)
View hooRAH's Photo Gallery
Originally Posted by orezok
No MIL codes.
How?
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline   Reply With Quote
Old 02-16-2007, 12:41 PM   #3 (permalink)
71Corolla's Avatar
Gameroom cash: $485050
View 71Corolla's Photo Gallery
^^ Was wondering the same thing.
BTW, if I'm understanding the service manual correctly, if the VSV is always getting 12 volts, then the EGR valve will never open and a CEL will show.
71Corolla is offline   Reply With Quote
Old 02-16-2007, 03:47 PM   #4 (permalink)
Orezok
The EGR never gets high vacuum at high RPM (test with gauge while driving). The VSV always has 12v (test with gauge). No MIL's, that's why I'm thinking ECU malfunction.
Old 02-16-2007, 07:24 PM   #5 (permalink)
71Corolla's Avatar
I see what you're saying. I would replace the ECU as a last resort though. I think it is much more likely that some other problem is causing the VSV to always have 12 volts (which closes off air flow and will prevent the EGR from ever opening)
I'm not sure what conditions the ECU is looking for before it cuts power to the VSV. I know that RPM and engine temperature are factored in, but not sure if there are other conditions it looks for.
Old 02-16-2007, 07:41 PM   #6 (permalink)
Orezok
Three conditions are required to activate high RPM VSV activation. Temp above 130, distributor input and vacuum. I put my computer based scan tool on and it is reporting out the correct temperature from the temperature sensor, the correct RPM (distributor input), but I don't know where the vacuum signal to the ECM is generated. Most likely from the manifold pressure sensor. I'll do some research on this one tonight and see if that is an issue.
Given that the engine is running perfectly, none of the 3 should be deficient. Trumping the whole situation again is that no MIL codes are being stored.
Could still be a bad ECM, but I'll keep looking.
Old 02-16-2007, 09:37 PM   #7 (permalink)
71Corolla's Avatar
^^ post back with your findings.
Old 02-17-2007, 08:34 PM   #8 (permalink)
Darkside Cut Me!!!
Gameroom cash: $127223
View Hajoca's Photo Gallery
Is hte EGR air filter dirty, and does the EGR piston move freely?
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 02-18-2007, 06:52 PM   #9 (permalink)
Orezok
4th Generation
Thought it was a bad MAP sensor, but I did a bad test (vacuum leak in mu pump). Still looks like ECM.
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 12:49 PM
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 02:04 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 11:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 01:49 PM
