How to change the front turn signal bulb on gen4? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2007, 08:33 AM   #1 (permalink)
Member
View triggerhappy007's Photo Gallery
4th Generation How to change the front turn signal bulb on gen4?
It looks like I can't access it without removing the turn signal assembly. I looked on page 5 of the body repair manual and it looks like you just pry it open with a screwdriver. I noticed that there is a plastic arm attached to the top. How do I get the arm off and the assembly out so I can replace the bulb?
Thanks everyone. It was a pretty easy job.
97 Camry LE I4 - 06 GS300 rims (11/06), Tokico HP/H&R Springs(1/07), Pioneer 7400MP, Polk DB675, OSRAM Silverstars (3/07), K&N filter
triggerhappy007 is offline   Reply With Quote
Old 02-17-2007, 09:29 AM   #2 (permalink)
nuchieboy's Avatar
Gameroom cash: $203299
View nuchieboy's Photo Gallery
4th Generation
u have to pull that top arm clip out...and then pull out slowly because there is another clip that holds the turn signal to the headlight housing..after that its pretty simple
2009 Camry SE V6 loaded
Mods: Borla Dual Exhaust with no resonator, K&N Intake, 5k HID headlights and 5k HID foglights, LED Tail lights, Complete interior leds, Ultra Racing Front Strut Bar, Ultra Racing 19mm rear sway bar, 20% tint, Rosen navigation system, 19 inch ASA GT1 wheels
nuchieboy is offline   Reply With Quote
Old 02-17-2007, 10:18 AM   #3 (permalink)
Member
How do I take the button on the top out?
Old 02-17-2007, 10:33 AM   #4 (permalink)
nuchieboy's Avatar
4th Generation
i used a flat head screw driver and basically wiggled it out...pry it under the clip and wiggle it out...thats what i did
Old 02-17-2007, 01:45 PM   #5 (permalink)
Every road's a playground
toyotaholic's Avatar
View toyotaholic's Photo Gallery
be patient on the clip thats connected to the headlight, its really stubborn
toyotaholic is offline   Reply With Quote
Old 02-17-2007, 07:31 PM   #6 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Owners manual has a step by step pictorial to follow.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 02-17-2007, 10:52 PM   #7 (permalink)
View fox_prime's Photo Gallery
If you look inside you'll see that it's clipped onto the headlight assembly. Use a flathead on:
1. The ugly push-in screw on top and
2. The clipped portion (press against it, outward...it should pop off it's locked position)
Once done, you'll have to slide the sidelamp out forward to access the bulb.
fox_prime is offline   Reply With Quote
Whiteline; Superpro and Dobinson Group Sale raptorracing Supporting Vendor Sales 222 03-09-2007 05:51 AM
Front Light Bulbs Model #, Turn Signal etc... deff808 2nd Generation (2005+) 15 05-05-2006 03:31 PM
Check Engine Light Problem Aaagogo Celica Forum 7 09-02-2004 05:46 PM
Drift Setting help for GT3 I hate Toyota Corp :( Off Topic 3 11-10-2003 10:36 PM
could you get away with it bondobondo General Discussion 46 07-06-2002 12:00 PM
