94 to 96 MAF (1-MZ) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2007, 03:58 PM   #1 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
94 to 96 MAF (1-MZ)
Does any one know if the mass air flow will work from a 94 1mz to a 96 1mz? The current one in my car is a bit faulty and i already have one from the junkyard, but some of the numbers are alittle different. The connector and everything else is the same. I just don't want to put it in and damage the computer. Thanks
V6LE_CAMRY is offline   Reply With Quote
Old 02-17-2007, 04:33 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
it should work fine, the only difference between the three years is that the 94 1mz has a different ingition setup.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 02-17-2007, 11:04 PM   #3 (permalink)
V6LE_CAMRY's Avatar
Thanks, im about to put it on. Ill tell you if it works fine.
Old 02-18-2007, 01:03 AM   #4 (permalink)
V6LE_CAMRY's Avatar
It worked fine no problems at all, took it all the way to redline a few times without any problems. let you know if anything pops out. bigbird thank you for you help.
96' I4 2.2 engine in a 94' wagon engine swap. Will it work? bennington28 3rd & 4th Generation (1992–1996 & 1997–2001) 1 09-27-2007 05:27 AM
94 4afe into 91 Corolla fabbb Archived Corolla threads 4 12-11-2006 08:19 PM
Quick Q? ..96 5sfe in a 94 Rolla? 02_vvt-i Archived Corolla threads 16 10-08-2006 01:40 PM
96 struts vs 94 chronoti 3rd & 4th Generation (1992–1996 & 1997–2001) 2 08-09-2005 01:13 PM
94' & 96' - Different Power Mirrors? arcasmachineracing 3rd & 4th Generation (1992–1996 & 1997–2001) 4 03-06-2004 04:45 PM
