IS 300 rims question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2007, 04:02 PM   #1 (permalink)
EvoFire's Avatar
View EvoFire's Photo Gallery
First off, I'm not here to ask if they fit my car or now, I'm actually wondering about something else. My friend told me that the Lexus rim needs a special type of lugnuts from Toyota/Lexus that costs $80. The Lordco guy(local parts store chain, dunno if they have it anywhere else) said most aftermarket lugnuts will fit and said I can get them for 5 bucks at Lordco.
I'm sure some of you guys have the IS rims now or before. Anyone want to chime in?
EvoFire is offline   Reply With Quote
Old 02-17-2007, 04:15 PM   #2 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
I think the reason it needs the Lex LugNuts is because they are longer. I think as long as you get a longer lugnut, all is well. The is just what I heave read before. I know several people here have them on.
So someone should post up before too long with the exact info you need.
Good luck.
5 Lug Corolla WHAT?
Old 02-17-2007, 04:32 PM   #3 (permalink)
93 240sx SR Hatch
DAMON's Avatar
iTrader Score: 36 reviews
View DAMON's Photo Gallery
I remember reading that they needed the lexus lug nuts as well, but I dont have hands on experience with them...
94 Camry (Beater) 99 Solara (Totaled) 93 240SX (Current)
DAMON is offline   Reply With Quote
Old 02-17-2007, 05:41 PM   #4 (permalink)
The Greek....
GrkBallaG's Avatar
View GrkBallaG's Photo Gallery
I think i may know what your talking about, i have these lugs on my car. The style of the lug nut actually lets it fit INSIDE the rim hole instead of just above the rim hole allowing for about 4-5 extra turns. When i put my brakes on i ran into a promblem because when i put the rim on and the spacer i could only get one turn out of my stock lugs. These lugs help me get about 5-6 turns on them and its all good. I think there called Conical seat bulge style lug nuts, but i cant find a pic of them.
The SLAMry.....
Slammed, Carboned, 5sp Swapped, Big Braked, RMM Lipped And Ready To Be Daily Driven!
Originally Posted by UfoZ View Post
Tits! Best non turbo Camry there is.
GrkBallaG is offline   Reply With Quote
Old 02-18-2007, 12:14 AM   #5 (permalink)
Member
View triggerhappy007's Photo Gallery
Not sure if the GS and IS lugs are similar, but mine came with washers so they fit flat against the wheel. The original Toyota ones are conical. If you ever need to use your spare, you better leave 5 old lug nuts or the Lexus ones won't work.
97 Camry LE I4 - 06 GS300 rims (11/06), Tokico HP/H&R Springs(1/07), Pioneer 7400MP, Polk DB675, OSRAM Silverstars (3/07), K&N filter
triggerhappy007 is offline   Reply With Quote
Old 02-18-2007, 04:15 AM   #6 (permalink)
EvoFire's Avatar
So would getting the normal lugs work, or would I have to dish out to get the Lexus/Toyota special lugs?
Old 02-18-2007, 07:48 AM   #7 (permalink)
The Other White Meat
terrastrife's Avatar
try a good tirestore, they should have eveyr possible type of lugnut cheap.
but yeah, the lexus wheels are hubcentric and use washer type nuts... the nuts side profile looks like T shape, not an acorn or log :P
terrastrife is offline   Reply With Quote
Old 02-19-2007, 02:01 AM   #8 (permalink)
EvoFire's Avatar
I'll post up whether I can find the needed lugs or not. I do hope I can find them at a tire store as $80 for lugs a bit insane.
FS: 17" 5-Bolt Rims w/ 225/45/17 Winter Tires Eye8Pussies Car Parts for Sale 14 10-11-2006 09:57 PM
Quick rims question for gen5 Mosquito 5th & 6th Generation (2002-2006 & 2007-2011) 0 07-09-2004 06:50 AM
ae92 rims question karma Archived Corolla threads 8 03-12-2003 02:16 PM
BMW bolt pattern rims to fit on an IS 300?? V6LE General Discussion 8 10-31-2002 02:29 PM
