1993 Stranded Need Help ASAP! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-18-2007, 08:05 AM   #1 (permalink)
View alfakarl's Photo Gallery
Unhappy 1993 Stranded Need Help ASAP!
Came out to start my 2.2 L 93 Camry the other day and it turned over fine, but would not start. I've got fire, had a weak orange-red spark and after testing the coil with a multi-meter determined it was out of spec and replaced it. Now I have sweet blue-white spark, but still no start. Tested all of the spark plug wires (within spec). Jumped FP & B on the the data link, turn the key to on and I can hear fuel pumping, but can't tell the fuel pressure (no guage). Tested the ohms reading on the fuel pump (within specs). I assume no fuel is getting into the cylinders, should I try starting fluid to see if it runs? What could it be?
Help!
alfakarl is offline   Reply With Quote
Old 02-18-2007, 09:41 AM   #2 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
Try the starting fluid.
How cold is it there? It's possible the gas filter has trapped some moisture and has frozen. A hair dryer on the filter for a few minutes plus some dry gas should help if that is the case.
DFBonnett is offline   Reply With Quote
Old 02-18-2007, 12:07 PM   #3 (permalink)
It's been between the teens and 40 for the past week. The car is in a garge now and has sat there for a day. I'll try the starting fluid and I think I have some methanol sitting around from my go kart.
Old 02-18-2007, 12:22 PM   #4 (permalink)
Uuugh! Tried the starting fluid and nothing.
Now what!?
Old 02-18-2007, 01:01 PM   #5 (permalink)
Gameroom cash: $303055
Did you pull the spark plugs to test for spark? If you tested for spark by putting a plug wire near a ground and cranking the engine, or used a spark plug that was lying around, I would pull the plugs and either clean them or replace them. They are probably now gas fouled, since the weak (orange) spark you were getting would not fire them. Now that you have replaced the coil and are getting the proper (blue) spark, chances are the plugs are too gas fouled to fire.
Mike
Old 02-18-2007, 01:09 PM   #6 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
i would definately check the plugs for wetness=gas covered. if so, put the plug back in, and go start it with the pedal on the floor! seriously, flooring the pedal while starting will keep the injectors off, while you start, so once it starts to run then let off the pedal...
as long as youve got spark, and wet plugs, try that, and you should be ok!
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 02-18-2007, 03:43 PM   #7 (permalink)
View BLstangin's Photo Gallery
Ya try holding it to the floor, it will put the whole system into flood mode and basically shut down fuel. The timing belt SHOULD be o.k. because you have spark, but it could have jumped and thrown your timing off. Just something to look at if it isn't flooded.
BLstangin is offline   Reply With Quote
Old 02-18-2007, 04:36 PM   #8 (permalink)
Axel Kain's Avatar
even if the timing is off a bit, it should at least spit, and sputter...
Old 02-18-2007, 05:26 PM   #9 (permalink)
View toyomoho's Photo Gallery
Download the service manual for the link below: The manual has excellent test and diagnostic sections.
Make sure you are getting spark at the plugs. You can bypass the fuel pump system cutout relay by jumping the FP and B+ terminals in the Diagnosis box then turning the ignition on. This will allow you to check the fuel system.
http://oregonstate.edu/~tongt/camry
Old 02-18-2007, 08:02 PM   #10 (permalink)
It's Alive!
Traced to a broken wire.
Thanks for all your help!
Old 02-19-2007, 12:22 AM   #11 (permalink)
Congrats!!!!
Old 02-19-2007, 09:27 PM   #12 (permalink)
Originally Posted by alfakarl
It's Alive!
Glad it's running again. Which wire was it?
Mike
1993 Toyota Camry LE (NEW YORK) structure Vehicles 0 04-17-2006 06:50 PM
1993 Camry gone :( Lots OF PIX!! jaigandhi5 3rd & 4th Generation (1992–1996 & 1997–2001) 16 04-23-2005 10:58 PM
1993 TOY Pick Up Engine Swap Cheech General Discussion 2 04-08-2005 11:25 PM
ASAP ASAP NEED 85 GTS alternator top-speed Archived Corolla threads 7 08-28-2003 08:29 AM
1993 V6 Camry XLE jump on this deal $2800 OBO SlowPoke Vehicles 5 07-23-2003 09:49 PM
