Power Steering Failure - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-18-2007, 05:15 PM   #1 (permalink)
97 Avalon Silver Spruce
View parimento1's Photo Gallery
USA Power Steering Failure
Was getting my car out of the snow today when I felt my car was hard to steer. I thought maybe there was some snow around the tires or something, but once I got it out, I noticed I had little to no power assist. I checked the fluid, which was totally full, so its not a leak. I looked in the reservoir to see if there were bubbles to see if the pump was working, and there were bubbles. I'm not sure what else it coud be...just replaced the steering knuckle and rack last year around this time...maybe it failed again. ALSO, i should add that when I rev the engine the steering assist returns but not 100%. When its idling there is no assist. Anyway, lemme know what u guys think
parimento1 is offline   Reply With Quote
Old 02-18-2007, 07:16 PM   #2 (permalink)
97 Camry
View Davee's Photo Gallery
You might want to check drive belt tension
Davee is offline   Reply With Quote
Old 02-19-2007, 02:10 AM   #3 (permalink)
View toyomoho's Photo Gallery
Did you try to bleed the system by turning the steering wheel fully CCW then fully CW.
Old 02-19-2007, 11:39 PM   #4 (permalink)
So I got the diagnosis today, the pump is bad and put metal into the whole system! What under the moonlight looked like dirt was actually metallic...shud be fun flushing that out!
Power Steering problem.. MR2crazybyong MR2 Forum 13 01-22-2006 08:22 PM
power steering fluid change gen3 OMNI 3rd & 4th Generation (1992–1996 & 1997–2001) 3 01-12-2006 02:23 PM
power steering fluid change gen3 OMNI 3rd & 4th Generation (1992–1996 & 1997–2001) 0 01-11-2006 05:46 PM
Power steering run dry - damage? Time to sell? PDXterra Celica Forum 8 01-06-2006 01:05 PM
Power steering noise after flushing/changing the steering fluid Camry 2001 Mark22 3rd & 4th Generation (1992–1996 & 1997–2001) 1 12-26-2005 12:34 PM
