I won't say what your problem is definitively, because it really could be anything without seeing the actual car, but if you're getting a leak on cold startup front the front side of the engine that goes away after the engine warms up, I'd bet on the oil pump O-ring, which is different from the oil pump shaft seal.
If you search my name, you'll find a handful of pictures and testing describing this leak. If it is leaking from anywhere on the front side of the engine that ISNT the valve cover, count on a timing belt job + all front engine seals. Water pump is up to you.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
