Could be the Throttle position sensor, on one of my car it had a "rough spot". It usto jump around at idle, like in stop and go traffic where you just press on the gas lightly. It also had a "rough spot" at high speed, don't remember exact at what speed it was, something between 55-70. It had like a flat point and when the car speed usto reached that point the car usto jerk back and forth. If that happens to be your case you can replace it yourself, but it might need to be calibrated with a volt meter to something like 0.5v between two cables when you put the new one in. ( this was back in early 90's, don't remember all the details) ...Can someone else back that up?
Second guess: might be the MAF sensor, with a volt meter you can test for resistance, you will need to know which pins to measure the resistance at.
Good Luck.
