lost power - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2007, 08:31 PM   #1 (permalink)
View TAckhouse1's Photo Gallery
3rd Generation lost power
So last week I had the knock sensors replaced in my car (1994 Toyota Camry V6). It was a PITA to have done, since the knock sensors were $165 a piece (one in each cylinder bank) and then another $380 in labor since they are under the intake manifold. But it was causing a check engine light, and the car wouldn't pass a upcoming emissions test with the light on.
The issue is that the shop replaced the knock sensors, and there is no more check engine light, but now the car feels down on power. It just doesn't push me back like it used when under hard acceleration.
The power delievery is also not as smooth. It seems to bog somewhat around 3k, and then surge are 4.5k rpm, it never used to do that.
The problem is I don't know how noticeable these issues are. I notice them, becuase I have driven the car for the past 100,000 miles. the bogging and surging isn't drastic, but I notice it. The idle is still smooth.
I'm just worried that the shop isn't going to be able to figure out what the problem is, or that they will tell me that everything is fine. I am pretty convinced its not. A little bit of me worries that it is just in my head (since I don't have anything concrete to point to, other then how it "feels")
Any ideas of what could be wrong?
TAckhouse1 is offline   Reply With Quote
Old 02-22-2007, 09:57 PM   #2 (permalink)
this is what i say >
v-cam's Avatar
View v-cam's Photo Gallery
Reset the ECU, see what happens after that.
True car enthusiasts are open-minded to everyone's creation
v-cam is offline   Reply With Quote
Old 02-22-2007, 10:04 PM   #3 (permalink)
Odaiba Romance
shingouki808's Avatar
iTrader Score: 8 reviews
View shingouki808's Photo Gallery
3rd Generation
I second v-cam's advice. If that doesn't work, when they removed the intake manifold did they clean it? If they left the intake manifold in the open it might have gotten all kinds of crap in it when they put it back. Clean that and the throttle body.
アクション カメン 只今 さんじょう!!! ブリ ブリ ブリ。。。。。。。。。。。。
shingouki808 is offline   Reply With Quote
Old 02-23-2007, 08:09 AM   #4 (permalink)
How do I do that? Is it just a matter of disconnecting the battery?
Old 02-23-2007, 09:33 AM   #5 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
i had my engine light on too.. i just did emissions 2 months ago and they told me that they wouldnt touch my car until the light was gone..
went around the corner disconnected the battery went back to the same place and my car passed!!! hahaha
but anyway i would start off cleaning your TB and IAC
did you have the codes read before you changed the knock sensor? stupid question but maybe work code
if you searched theres a few on peeps here on TN with the same problem, (were it bogs down)
but i dont think anybody found the problem
Old 02-23-2007, 09:36 AM   #6 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
You could disconect the battery for say, 5 minutes or so.
geoff5093 is offline   Reply With Quote
Old 02-23-2007, 01:03 PM   #7 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
ah, damn...too bad you already got the job done and paid a fortune for it as well....
it has to do with the sensitivity of the ecu to the knocksensor signals in the 94 1mzfe. and NO, you are no imagining the power loss.
I advise that you start learning how to work on your own car, otherwise you will have to live with this problem....or pay another pretty penny to get it fixed.
read my threads:
knock sensor relocation:
http://toyotanation.com/forum/t157503.html
dyno after relocation:
http://toyotanation.com/forum/t158255.html
HaHa
Old 02-23-2007, 05:41 PM   #8 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
it (i hope not) could be that the mechanics didnt properly seal your intake parts. and the engine is not mapped for the excess air it's getting. but i also recommend trying the ecu reset first!
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 02-23-2007, 08:15 PM   #9 (permalink)
TN Pussy Man
^ nope...it wouldn't be that....and generally speaking, power loss isn't too great with vacuum leaks, especially during WOT, since the ecu id dumping fuel anyway.
but more so, it'll be obvious during idle
and you can try resetting your ecu, but if it's knock sensor related, if there's no code, then resetting the ecu won't do anything- and if there is a knock sensor code, then resetting will nothing as well. it will just come back on once the throttle is touchec
HaHa
Old 03-06-2007, 03:25 AM   #10 (permalink)
View mike6466's Photo Gallery
it could just a loose cap or something. try changing your gas. that what i did and my light went away.
mike6466 is offline   Reply With Quote
Old 03-06-2007, 01:24 PM   #11 (permalink)
View geokor's Photo Gallery
do thorough check of vacuum hoses, make sure they are connected properly and none of the fittings are broken. Also, check distributor wires (looseness, damage etc). I can't tell you how many times i got car back from dealer repairs with loose hoses, wires. Fortunately, i don't bother with dealers anymore.
geokor is offline   Reply With Quote
Old 03-06-2007, 03:17 PM   #12 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
hmm, i didn't know the 1MZ-FE has distributor wires.
my 94 V6 was in the shop for inspection, and the mechanic said it was severly under power, i am thinking i need a tune up, but don't know where to start. . . .
spark plugs, fuel filter, clean throttle body, coolant flush, do i need to change the spark plug coil?
bronzemaxell is offline   Reply With Quote
Old 03-06-2007, 03:55 PM   #13 (permalink)
TN Pussy Man
the 94 doesn't.
but the 96 and up have sparkplug wires that run off the other three coils.
and if a car is severely under powered, there is something wrong and a tuneup won't fix it. if a car is feeling a bit more sluggish, then a tune up could help.
and you shouldn't have to change the coil packs unless it dies
HaHa
Old 03-07-2007, 01:52 PM   #14 (permalink)
Sorry, I meant sparkplug wires. You can check resistance of wires and check coils.
Old 03-07-2007, 09:08 PM   #15 (permalink)
Thanks for the responses guys. I took it back to the shop. They checked everything and made some adjustments. The car seems to be driving better now.
J.D. Power 2006 Vehicle Dependability Study ScubaGuy 2nd Generation (2005+) 13 08-10-2006 11:38 AM
Help lost lights and power windows rcmathis Archived Corolla threads 1 05-28-2005 05:51 PM
lost power: spark or injector?? underspecial Supra Forum 6 04-10-2005 08:48 PM
decrease in power! HELP! kasimmmmm General Discussion 17 04-21-2004 09:20 PM
