1996 Camry engine quit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-24-2007, 06:50 PM   #1 (permalink)
View DustyRoads's Photo Gallery
Recently driving down Interstate at 65mph. Camry suddenly sputtered twice (like a gas flow problem) and then totally shut down. Coasted onto off-ramp and got towed home. Car would not restart. It would turn over, but not start. And I have gas!!!
Since then I checked my fuel pump (it works), fuel filter was replaced less than a year ago (checked it anyway and fuel is pumped through strongly), replaced my distributer rotor and cap and replaced my spark plug and coil wires.
Still turns over, but will not start! any ideas?
DustyRoads is offline   Reply With Quote
Old 02-24-2007, 07:31 PM   #2 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Did you make sure your getting spark?
5 Lug Corolla WHAT?
Old 02-24-2007, 07:59 PM   #3 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
check the maf sensor thing
Old 02-24-2007, 09:16 PM   #4 (permalink)
View toyomoho's Photo Gallery
Is the timing belt broke? Check to see if the rotor is turning.
Old 02-24-2007, 10:47 PM   #5 (permalink)
just thought of something
did you check out all the fuses!???
under the hood and inside???????
theres a few fuses that if there is a blown fuse the car wont start at all..
i mean there was a fuse i didnt put back inside a 7.5a fuse that i think was for the ign and my car wouldnt start without it
Old 02-25-2007, 03:34 PM   #6 (permalink)
Gameroom cash: $303055
You need to start with the basics. Some one above mentioned to check for a broken timing belt by removing the distributor cap and cranking the engine. If the rotor is turning, the timing belt is OK. If it is not turning, the timing belt has snapped. Assuming the rotor is turning and the timing belt is OK, next thing would be to check for spark at the plugs. Pull one of the spark plug wires and one of the plugs (or use an old plug in the plug wire). Lay the plug on any metal part in the engine block to ground it and crank the engine. Look for spark. You should see a nice blue spark. Let us know what happens after these 2 tests and someone will give you further instructions.
Mike
How to replace rear engine mount in 1996 Camry, 4 cyl? basil 3rd & 4th Generation (1992–1996 & 1997–2001) 5 03-02-2012 06:34 PM
For sale 1993 Camry SE 5 Speed with J spec V6 engine amg280 Vehicles 1 01-07-2011 11:12 AM
Toyota Engine code vivian General Discussion 22 12-27-2008 01:16 AM
2000 camry engine problems help? LONG jotka 3rd & 4th Generation (1992–1996 & 1997–2001) 10 03-24-2006 10:16 PM
Camry quit on me, Check engine light on-off mandyfig Camry & Solara Lounge 9 08-16-2005 04:49 PM
