1MZ-FE Sludge issue, intersing spotting and discussion I guess. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-26-2007, 01:29 AM   #1 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Talked to Eye8Pussies for a while about this, and decided to post it up, as we both found it interesting. As I was putting my Valve covers back on, I noticed a little sludge. SAME spot on both banks. Rear one had is in a hole, anout 8mm wide, by the timing belt cover, and same for the front. that is the ONLY place there is sludge in the engine. Now, is that just normal, or is that how the sludge starts? I have a feeling Toysrme will know the answer to this.
5 Lug Corolla WHAT?
Old 02-26-2007, 11:48 AM   #2 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
i dont think you have anything to worry about. if im remembering correctly, oil collects in that hole and there isnt a way for it to drain out (unless you roll your car).
Old 02-26-2007, 11:52 AM   #3 (permalink)
^ Yeah, I figured it's fine. Was pretty much wondering if that is an area it starts in before the hole gets clogged. How did yours clean up BTW?
5 Lug Corolla WHAT?
Old 02-26-2007, 12:15 PM   #4 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
a good amount of crap kind of seeped through my original engine's seal at that area. Looking like a pretty clean engine tho.
nodrogkam is offline   Reply With Quote
Old 02-26-2007, 12:20 PM   #5 (permalink)
I only use Syn, and used seafoam once. Not sure how much of a diff that made in it being clean. I drive the car HARD!!!! Had Dino oil till 60k when I bought it, and have used Syn from about 65k miles to now, 93k miles.
5 Lug Corolla WHAT?
Old 02-26-2007, 03:42 PM   #6 (permalink)
97 Avalon Silver Spruce
View parimento1's Photo Gallery
my engine looked like that when I pulled the valve covers. Had some build-up but nothing major. After I saw it I stopped doing 4k mile oil changes and went to 3k
parimento1 is offline   Reply With Quote
Old 02-26-2007, 03:58 PM   #7 (permalink)
ghettosled's Avatar
i havent cracked open the valve cover since that cleaning a while back. this spring ill do another seafoam treatment then take the cover off to see the results.
stay tuned...
Old 02-26-2007, 09:16 PM   #8 (permalink)
View Kitto's Photo Gallery
I think this one can help you: http://www.auto-rx.com/
highly recommarded by http://www.bobistheoilguy.com
try at your own risk, but I only heard good things about it.
if you have question, just post on bobistheoilguy fourm.
Kitto is offline   Reply With Quote
Old 02-27-2007, 05:12 AM   #9 (permalink)
I am just a newbie!
Tony the Tiger's Avatar
View Tony the Tiger's Photo Gallery
Switch over the synthetic (only if your oil seals, gaskets, etc.. are in good shape) and you will be able to clean off all the sludge inside the engine over time. If you can't afford full synthetic, you can give the Valvoline MAX life a try because it is meant for high mileage engines and has stronger detergents to aid cleaning deposts/sludge in the engine.
* Goal for 2012 -- 200+ MPH in the Camry
Tony the Tiger is offline   Reply With Quote
Old 02-27-2007, 09:59 AM   #10 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
^ thats the stuff i use. my seals were to worn to use synthetic, but that max life has worked well for me. when i pulled my covers off 2 months ago it looked a little better, that migh have been the seafoam i had used like 3 months eariler though.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 02-27-2007, 12:34 PM   #11 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Seafoam FTW. Auto-rx only argueably works & at that it takes FOREVER to do anything if it actually does.
You're fine adam.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 02-27-2007, 09:54 PM   #12 (permalink)
Thanks all. I cleaned the crap out that WAS there. I figure I'll do the Seafoam one more time. I KNOW the previous owners did not take care of the car too well, but thankfully, I got it at 60k miles before they could do much damage.
5 Lug Corolla WHAT?
