put too much oil in; now half inch above F on dipstick. should I drain the extra out? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-26-2007, 06:17 PM   #1 (permalink)
View horvath's Photo Gallery
On the last oil change I put too much oil in; it is now half inch above F on dipstick. should I drain the extra oil out?
horvath is offline   Reply With Quote
Old 02-26-2007, 06:33 PM   #2 (permalink)
alotawatts's Avatar
View alotawatts's Photo Gallery
Yes
YES. You have at least 1 qt too much. Not good.
04 Highlander 01 4Runner 00 Camry 90 Chev S10
alotawatts is offline   Reply With Quote
Old 02-26-2007, 06:42 PM   #3 (permalink)
cardomain.com baggedcamry
BAGGEDCAMRY01's Avatar
View BAGGEDCAMRY01's Photo Gallery
yep get rid of the extra oil u can blow ur engine
BAGGEDCAMRY01 is offline   Reply With Quote
Old 02-26-2007, 07:14 PM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
how exactly did you overfill?
a bottle of oil is 5 liters, you put 4 in, leaves 1 spare... o_O
terrastrife is offline   Reply With Quote
Old 02-26-2007, 07:20 PM   #5 (permalink)
I put 4.5 qts, by mistake, stopped too late. I didn't think it was a big deal. Is it really bad? I already drove 100 miles. Permament damage? (96 Camry 5SFE)
Old 02-26-2007, 07:28 PM   #6 (permalink)
View 94CoupeV6's Photo Gallery
No you're fine don't worry about it man. If you drove it like that for a long time, then it would matter.
94CoupeV6 is offline   Reply With Quote
Old 02-26-2007, 10:23 PM   #7 (permalink)
View GaryS's Photo Gallery
Excess oil in small quantities is not that big of a deal. Won't blow your engine or other significant issues. The big issue is you REALLY overfilled it - then you would be talking about foaming, loss of lubrication and other issues. If you were talking about an auto tranny then the comment would be different. You are only .5 quart above the normal level. Leave it alone and drive the car.
GaryS is offline   Reply With Quote
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
Synthetic Oil KingofDiamonds General Discussion 32 01-08-2006 08:38 PM
Retrofitting Other Car Model Wheels With Gen3 (5x114.3) A2brb 3rd & 4th Generation (1992–1996 & 1997–2001) 13 11-11-2005 09:55 PM
Oil Drain Plug Gasket rickmadison Camry & Solara Lounge 5 05-09-2005 11:50 PM
Amount of Oil you put in your Toyota TRDragoon Hardcore Tech and Competition 11 08-22-2004 12:38 PM
