A540 Converter Re-Install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2007, 12:20 AM   #1 (permalink)
View repapyob's Photo Gallery
Is there anybody that has experience properly re-istalling their converter into an A540? (92 Camry V-6). I've trashed two pumps, and can't figure out what's going wrong. It seems like the converter "seats" in the pump drive, but when I start up, it's grind pop and gone.
repapyob is offline   Reply With Quote
Old 02-27-2007, 12:25 AM   #2 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
got enough oil in that bad boy?
converter holds quiet a bit, 2-3 quarts if i remember
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 02-27-2007, 12:27 AM   #3 (permalink)
Well It only seems to hold about 1 qt whenI re-fill it.
Old 02-27-2007, 01:44 AM   #4 (permalink)
View toyomoho's Photo Gallery
For a 540E, refill from dry is 6.2 qts (2.6 qts drain and refill). For a 540H 7.4 qts (3.5 qts drain and refill). Also make sure the torque converter is seated at the right depth. Some of these installations require measuring the depth. The link below provides access to Toyota service manuals.
http://oregonstate.edu/~tongt/camry
Old 02-27-2007, 10:15 AM   #5 (permalink)
Thanks for the info. I have been measuring the converter depth, shows OK, but when I bolt the converter up to the flex plate the converter pulls back towards the block. My guess is this is the problem, that the converter drive is dissengaging from the oil pump drive. The car only has 90K on it, I can't imagine the flex plate is bad. It worked fine before I pulled it.
Old 02-27-2007, 09:10 PM   #6 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
i got a 2800rpm high stall custom torque-convertor sitting here if u wanna buy it
what's the line pressure at a warm idle?
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 03-24-2007, 12:34 AM   #7 (permalink)
Sorry for the so reply, been busy rebuilding the tranny. Wasn't the converter after all. Was the oil pump jammed into the front clutch assembly, due to missing information from the Toyota factory manual. Seems you need to relieve tension from the front "band" as there's a spring loaded piston that needs to be removed before you pull the oil pump, and re-install it. So to anyone who's reading, be SURE to pick up the ATSG manual from a tranny supplier BEFORE attempting any work on an A540. The Toyota manual is not what you need. Happy wrenching!
7 pin with Converter? roatan4us 2nd Generation (2005+) 8 12-14-2005 12:37 AM
5sfe Engine Install xylium 3rd & 4th Generation (1992–1996 & 1997–2001) 9 04-08-2005 02:07 AM
Worse MPG With New Catalytic Converter 99Solara General Discussion 4 12-11-2004 06:33 PM
Torque Converter upgrade lecamryv6 Camry & Solara Lounge 4 12-09-2003 07:47 PM
Rod Millen 92-94 Add-on Install Zer05 3rd & 4th Generation (1992–1996 & 1997–2001) 3 10-28-2003 10:25 AM
