Throttle Body Upgrade? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2007, 01:09 AM   #1 (permalink)
View 94CoupeV6's Photo Gallery
I don't think this has ever been discuessed, at least not while I've been a member. This is in regards to the V6 guys.
-How large is the stock TB size (mm)?
-Are there any other Toyota TB's that are larger and would possibly work on the 1MZFE? Or do the newer 1MZFE's have a larget TB than we do? If not Toyota, would any larger TB work on the V6? I'm assuming this would yield a little bit of horsepower.
My friend brought it up and I have never seen any information about it here on ToyotaNation. So, does anyone have any input on this topic, because I know none of the V6 guys on this website have an upgraded throttle body.
94CoupeV6 is offline   Reply With Quote
Old 02-27-2007, 08:08 AM   #2 (permalink)
Nobody knows eh?
Old 02-27-2007, 09:10 AM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
das a good question, but wouldnt you have to modify the MAF sensor so it dont trip a code? most cars ive seen that try to get any gain out of that have had to get or modify the mass air flow sensor.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 02-27-2007, 08:59 PM   #4 (permalink)
engineer in training
Gameroom cash: $145055
I don't know why they would have to modify the maf sensor. Might have to modify it to fit on another throttle body but thats about the only reason I can see for doing this, I had to get a new 85mm MAF and an adapter when I upgraded from my stock 65mm TB to the Northstar 75.5mm.
Now, upgrading the throttle body on some cars (my GP for instance) is a good mod when the engine is flowing more air than the throttle body can allow in, but it isn't going to be the case on a n/a 3.0 Camry. For one thing you don't have the cams to allow you to make use of all the available bolt on mods, if you were to get some nice mid/top end cams (and the necessary supporting mods like springs and new buckets (shim-less or shim-under style)), up the rev limiter, get some long tube headers and port and polish the intake, then spend hours upon hours tuning for all the extra power you could look at upgrading the throttle body. Until you at least do cams stick to the easy stuff like a cone filter intake
Unfortunately no one I know of just makes cams for a v6 Camry, also no one I know of is willing to spend 800-1000+ dollars on cams, even though thats one of the only ways to up the power output.
Gotta love the OHV engines, 1 cam, its a bitch to swap it out, but man it makes a difference!
Peel out after cleaning throttle body? Blackhawk3D Camry & Solara Lounge 40 04-03-2007 07:01 AM
Question with regards to the throttle body Ghost Archived Corolla threads 0 10-05-2005 03:19 PM
Throttle Body Problem? ghost99x MR2 Forum 3 10-04-2005 01:48 PM
Throttle body upgrade? boostedsolara Camry & Solara Lounge 0 01-29-2004 08:11 PM
