1mz or 3vz - whats your favourite? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2007, 10:12 PM   #1 (permalink)
this is what i say >
v-cam's Avatar
View v-cam's Photo Gallery
Australia 1mz or 3vz - whats your favourite?
I have been interested in the differnece between the 1mz and 3vz and im wondering peoples opinions on which engine they prefer.
I know the 1mz is distributerless with coil-packs has the OBD-II computer and slightly more power, but after driving the gen 3 (strictly 3vz only here in Australia) and the Gen 4 (first of the 1mz) I tend to like the 3vz better. It seems more 'gruff' and has a real sweet willingness to rev to the limiter. Low rpm with heavy throttle sounds deeper and more 'angry' ... I reckon it has more character over the 1mz... what do you guys reckon?
True car enthusiasts are open-minded to everyone's creation
v-cam is offline   Reply With Quote
Old 02-27-2007, 10:48 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
well i know people like the 3vz for its higher strength, some people like the 1mz's power(not much of a difference). personally ive only owned the 1mz but since both were gen3 they both had the PWR button that allowed the revs to reach redline. gen4+ didnt have that little feature. i have driven both 3vz and 1mz of the gen3 and never really noticed much of a differance.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 02-27-2007, 10:55 PM   #3 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Well you have to ask yourself the question of which 1mz-fe? the 94-96, the revised intake, the vvt-i, or those + dual tb's & the plastic manifold.
regardless, i'd rather have a 3vz-fe. i have to fewer penalties to pay for too many benifits.
in complete form a 3vz-fe:
  • is less than 100lbs heavier...
  • has a MUCH stronger bottom end, especially the pistons, which are an older style of construction & have nearly a point less compression.
  • rods are bigger
  • iron block... The mz aluminum block in the SAE engineering paper actually has 20% more regidity. OK... the 3vz-fe has a huge aluminum girdle holding the amin bearings down that most people pay $200-400 for to be made custom.
  • never had OSKSS (Over-sensative knock sensor syndrom)...
  • no pre-cats, no emessions monitoring & a mpg less economy - yes. I clubbing baby seals with my emessions control-less ES 300.
  • The OBD-I management is much simpler, and you can get it to do strupidly large changes with quality piggybacks & planning. Shit that you'd never attempt on an OBD-II engine to the scale you could on this engine...
  • Has an AFM that looses 3.7bhp @ .7ft-lbs of torque @ 330bhp. That's not very much...
  • AFM allows adjustable idle mixture, and a corase mixture adjustment... free...
  • Distributor easy to deal with electrically, and can change base timing events... free...
  • Ignition upgrade is simple. Put in an MSD coil & forget about it. (1mz-fe's have no such easy ignition ugprade. wasted spark ignition expencive to upgrade. '94 COP ignition is more SOL when you hit the point of needing more spark.)
  • 3vz-fe makes 185bhp/195ft-lbs, is easily tweaked to make 200bhp/204ft-lbs
  • 3vz-fe's management allows 7100-7500rpm untouched before a hard fuelcut, redlines @ 6850rpm. I've logged mine on my old smt6 running 7500rpm before fuel-cut. now a pair of 3vz-fe mr2 v6 swaps have confirmed that... toyota tachs are too ******* laggy...
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 02-27-2007, 11:07 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
damn u toys, now i want one
FS: used 1mz
R.I.P.
Car Domain:
Old 02-27-2007, 11:35 PM   #5 (permalink)
Toysrme's Avatar
Cool
well look that's not to say the 1mz-fe doesn't have a nice big of pluses over the 3vz-fe
Now with Turbo!
Old 02-28-2007, 12:03 AM   #6 (permalink)
Unco's Avatar
View Unco's Photo Gallery
after driving 6 cyl commodores and falcons i was pleasantly surprised with the low range response of the 3vz. without flooring it or redlining it, the 3vz seems to pull away nicely from a light touch of the accelerator when cruising at 60-70kph. i believe the 1mz has a totally different power/torque line, but i haven't driven one to compare it.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 02-28-2007, 12:08 AM   #7 (permalink)
v-cam's Avatar
"3vz-fe makes 185bhp/195ft-lbs, is easily tweaked to make 200bhp/204ft-lbs"
easily?
Old 02-28-2007, 02:37 AM   #8 (permalink)
The Other White Meat
terrastrife's Avatar
older falcodores have shit auto trannys, period. theyre more grunty down down low but the boxes are piss crap.
terrastrife is offline   Reply With Quote
Old 02-28-2007, 03:19 AM   #9 (permalink)
View 94CoupeV6's Photo Gallery
Hmmm I have never driver the 3VZFE...but I NEED to own a coupe V6, so 1MZFE it is!
94CoupeV6 is offline   Reply With Quote
Old 02-28-2007, 03:25 AM   #10 (permalink)
i prefer the 1mz's power to the 3vz, its much more smoother (who the hell says teh 3vz is more?)
although the standard tranny vavle pressure is toow eak... gear changes are slooopy
Old 02-28-2007, 01:52 PM   #11 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
never had the 3vz so ima have to go with 1mz
Old 02-28-2007, 02:08 PM   #12 (permalink)
Toysrme's Avatar
Cool
easily?
lean the cog, give it another 5* of timing
200bhp and gobs of torque.
1mz is more of a midrange engine.
Now with Turbo!
Old 02-28-2007, 05:09 PM   #13 (permalink)
Gangsta SC400 & 5.7Tundra
iTrader Score: 35 reviews
View -SCWEET1-'s Photo Gallery
I know this goes against what Toys thinks but 5VZ FTW!
-SCWEET1- is offline   Reply With Quote
Old 02-28-2007, 05:27 PM   #14 (permalink)
Toysrme's Avatar
Cool
only for the trucks.
i'd rather have a powerband to compliment the transmission in the vehicle lol!
Now with Turbo!
Old 02-28-2007, 05:30 PM   #15 (permalink)
Yeah, understandable, but I am not doing it to run it hard, just doing it because I can... LOL
1Mz & 3vz con rods UK_MRV6 Camry & Solara Lounge 13 06-04-2005 02:15 PM
how much hp/tq can a 3vz and 1mz take njbmx Camry & Solara Lounge 26 01-18-2005 06:39 AM
3VZ axles vs 1MZ axles mobes Hardcore Tech and Competition 3 09-30-2004 09:20 PM
Engine swap for gen 4 war0827 3rd & 4th Generation (1992–1996 & 1997–2001) 77 06-29-2004 09:59 PM
3vz to 1mz swap rubicinc General Discussion 10 05-13-2004 12:24 PM
