can we remove the metal header cover? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2007, 07:23 AM   #1 (permalink)
View coquibone14's Photo Gallery
hey all, i was wondering if we could remove the metal header cover that has the "hot" symbol on it. this is for a gen 4 5sfe 4 cyl. thanks
2001 LE
pioneer Avic D1 (GPS indash)
1 12's and 1200 watt amp (pioneer)
18' ICW Mach 10 rims with low pro's.
coquibone14 is offline   Reply With Quote
Old 03-01-2007, 07:42 AM   #2 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
you can, there should just be some screws holding it in place.
Old 03-01-2007, 07:44 AM   #3 (permalink)
Unco's Avatar
View Unco's Photo Gallery
but doesn't it also act as a heatshield?
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 03-01-2007, 07:52 AM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
its probably hotter outside then under the bonnet in FL :P
terrastrife is offline   Reply With Quote
Old 03-01-2007, 08:12 AM   #5 (permalink)
thats what i was thinking, since it is up high in the engine, i would like to remove it but i dont want it melting my hood or messing with the paint on the hood, or melting the fabric thing under the hood.
2001 LE
Old 03-01-2007, 11:32 AM   #6 (permalink)
Check Out That Camry!!!!
CAMRYTUNER20's Avatar
View CAMRYTUNER20's Photo Gallery
I Have The Header And You Cant Put The Heat Shield On That So I Dont Think It Would Make A Difference
KEEP THE PIMP HAND STRONG!
CAMRYTUNER20 is offline   Reply With Quote
Old 03-01-2007, 12:17 PM   #7 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
lol heres how to think about it, theres a heat shield on ur hood (fireproof material or w/e) and so ur paint will be OK. i have the v6 that runs WAY hotter than your i4 and mine never even came with a head shield. Besides the radiator fans that look yellowed with white lines all over them (looks like they're going to crack cos of heat), everything on my car is fine.
u can certainly remove it. but why?
nodrogkam is offline   Reply With Quote
Old 03-01-2007, 04:01 PM   #8 (permalink)
Unco's Avatar
my 86 celica (3SGE) had the headshield removed AND the bonnet (hood) lining removed before i bought it.
on a rainy day, steam rises from the top of the bonnet every time i stop at the lights and although most of the paint work is faded, the bonnet is the worst affected section.
also, most of the wiring sitting anywhere near the exhaust manifold has gone brittle.
i'd say leave it on. it's there for a reason, not just so that they could put a hot symbol on it.
Old 03-01-2007, 06:13 PM   #9 (permalink)
View Grayguy's Photo Gallery
I dont' have that heat shield because it was rattling. Between not having the heat shield, and not having that pad crap, the hood gets pretty warm. The only issue I've had is when my car's just sitting around idleing, snow melts and runs off the hot hood, and then when it hits the cool front end, it freezes and ice builds up.
Grayguy is offline   Reply With Quote
Old 03-01-2007, 06:59 PM   #10 (permalink)
cardomain.com baggedcamry
BAGGEDCAMRY01's Avatar
View BAGGEDCAMRY01's Photo Gallery
well i took my heat shield off to get chromed and my hood does not get hot and i dont have any heat mat underhood either
BAGGEDCAMRY01 is offline   Reply With Quote
Old 03-01-2007, 07:04 PM   #11 (permalink)
Unco's Avatar
of course, it won't happen overnight. but long term effects will be evident later on. if you're not going to keep the car for more than 3-5 years, then i don't think you'll notice any issues.
Old 03-01-2007, 07:13 PM   #12 (permalink)
nodrogkam's Avatar
not having the pad will result in premature paint fade etc, even if you have the heatsheild.
HOWTO remove the rear bumper cover on a 2003 camry? cas 5th & 6th Generation (2002-2006 & 2007-2011) 3 10-27-2011 11:59 AM
Headers on a AE92 HEAT WRAP"? Darien18 Archived Corolla threads 13 01-10-2007 06:18 PM
dashboard & front seats Midnight87 Supra Forum 6 07-09-2006 05:09 PM
anybody got pics. of your corolla xrs engine cover? xrs22 Archived Corolla threads 2 05-06-2005 05:15 PM
How do you remove the cover? Eye8Pussies Camry & Solara Lounge 12 09-21-2002 03:46 PM
